My setup has started producing a distinct high-pitched whine at about 9-10k, although its hard to tell exactly as that's about the same pitch as my tinnitus! But it's definitely there.
I have a Focusrite Scarlett 18i20 Mk.2 and 2 Neumann KM-80's. Switching everything off, then on again has made no difference. Any ideas? Thank you.
High-pitched whine
• Page 1 of 1
Re: High-pitched whine
Lots of potential sources.... but I'd start by checking the locations of any switched mode power units. They operate at high frequencies and can sometimes radiate nasties into nearby audio cables. So moving them -- and even just changing their orientation -- can sometimes help.
Another possibility is a failing switched mode supply, or a failing DC-DC converter inside one device, so try turning off individual items to see if you can track the problem down to a single device.
Yet another cause is ground loop noises, often emanating from the computer. So try disconnecting audio cables to see if you can track down where it's getting in... and then follow the usual ground-loop curing techniques if that looks a likely candidate.
Hugh Robjohns - Moderator
Thank you for your response, Hugh. That gives me something to get my teeth into for the next day or so...
Ben
Ben
- baward
- Regular
Hi Ben,
Further to Hugh's excellent advice, you may find this SOS step-by-step guide I wrote for tracking down ground loop problems useful - its pays to be very systematic, and you can use it to quickly confirm whether or not ground loop problems are the reason for your 9/10kHz noises, before exploring possible PSU nasties and similar issues.
https://www.soundonsound.com/sound-advi ... -my-studio
Martin Walker - Moderator
