The old Win XP driver for Behringer Xenyx Q802
Re: The old Win XP driver for Behringer Xenyx Q802
Postby Wonks » Mon May 17, 2021 10:01 am
This is the latest version of ASIO4ALL (V2.14) I could find that supports XP. If you haven't tried it with the Xenyx, then I suggest you give it a go.
https://www.asio4all.org/downloads_11/A ... nglish.exe
And make sure that the ASIO4ALL driver is selected in your software. Just loading it onto your PC won't be enough.
Postby ef37a » Mon May 17, 2021 3:51 pm
If push comes to shove, buy a UCA 202. I no longer have an XP machine to try mine on but I am sure it will work.
Even if you got the 802 to work, being a very early, 16 bit USB interface it is sure to suffer from the dreaded "16 bit USB whine". The 202, despite being 16 bit seems not to.
Postby James Perrett » Mon May 17, 2021 4:46 pm
ef37a wrote:Even if you got the 802 to work, being a very early, 16 bit USB interface it is sure to suffer from the dreaded "16 bit USB whine". The 202, despite being 16 bit seems not to.
I think it depends Dave - my UCA222 certainly suffers from a whine (which are possibly idle tones) sometimes but not all the time. Mine has a date code of 1704 (April 2017 as I understand it).
Postby ef37a » Mon May 17, 2021 5:15 pm
Have you got Windows Record Gain set to 5% or less James? That should push any whine below 'source' noise, especially those horrible 305mm black things!
Postby blinddrew » Mon May 17, 2021 8:31 pm
My 1202 didn't suffer from that whine.
Postby ef37a » Tue May 18, 2021 9:49 am
blinddrew wrote:My 1202 didn't suffer from that whine.
Yes, the problem does seem very haphazard. I suspect it is some sort of interaction with certain USB drivers or/and certain MOBOs?
But then WTF do I know!
Postby blinddrew » Tue May 18, 2021 10:15 am
More than me! :D
Postby James Perrett » Tue May 18, 2021 11:05 am
ef37a wrote:Yes, the problem does seem very haphazard. I suspect it is some sort of interaction with certain USB drivers or/and certain MOBOs?
I think the problem knows when you need to get something done in a hurry. I never managed to make it happen when I had time to track it down.
