Icon QCon Pro G2 and Reaper
Re: Icon QCon Pro G2 and Reaper
Postby blinddrew » Mon May 10, 2021 8:56 pm
Ok, bearing in mind that I don't have an Icon and I'm not sure exactly how you're configuring it, but does it need to be active in both places? I have my BCR set up in the control surfaces section but disabled as a midi device.
Postby Marbury » Mon May 10, 2021 9:01 pm
Ok, I just thought you would have to identify it in the midi section so it can be picked up in the control surface section. I will try that though and report back.
Marbury
Postby blinddrew » Mon May 10, 2021 10:01 pm
It might need to exist in there, not sure, but it shouldn't need to be enabled.
Postby Marbury » Tue May 11, 2021 12:13 am
Nope, disabling in the midi section has no effect. It still shows up in the control surface in preferences but is unresponsive. It seems intermittent as every so often, doing the same actions links it up fine. I then shut down Reaper, open again (same settings) and the Qcon is again left out in the cold unresponsive. So why would it work intermittently ? It's not logical.
Marbury
Postby blinddrew » Tue May 11, 2021 12:40 pm
Unfortunately we're now beyond my ken. Only thing I can suggest is asking on the Reaper forum. :(
Postby Marbury » Wed May 12, 2021 9:19 pm
Have no fear, I have managed to get it to consistently work with the mackie configuration which does the job. I will quit while I am ahead. Thanks anyway for your suggestions in the head scratching department.
Marbury
Postby blinddrew » Wed May 12, 2021 9:22 pm
No worries, glad you've got it going to some degree.
Postby Marbury » Thu May 13, 2021 12:41 pm
It's not perfect, doesn't do everything I want it to (undo/redo) but covers the basics and is aesthetically nice to use.
Marbury
