Dither confusion
Dither confusion
Postby RichardT » Sun Apr 11, 2021 5:56 pm
I’m confused - should I dither or not when converting from Cubase’s internal 64 bit floating point representation to 24 bit PCM?
As far as I can see, the dither signal is around -140dB when outputting at 24bit, which is way below the noise floor of any real world converter.
And yet some people who should know say that yes, you should dither when reducing word-length to 24 bit.
What’s the truth here?
RichardT
Re: Dither confusion
Postby Hugh Robjohns » Sun Apr 11, 2021 7:26 pm
The rule is very simple: a digital signal MUST be dithered whenever the word-length is reduced.
I'd like to think Cubase would do it automatically for a fixed-point 24 bit output, but if it doesnt then technically yes, it should be manually dithered.
While it is true that your A-D converter (or ambient recorded acoustic) noise floor will be well above the -141dBFS 24-bit digital dither noise floor during the playback of recorded audio, that won't be the case when fading down or up from 'digital silence' between tracks. So while the quantising distortions due to the lack of dither might well go noticed by most listeners, you cant guarantee it and you will definately get technically better results if you do dither the output.
Postby RichardT » Sun Apr 11, 2021 7:30 pm
Thanks Hugh, that makes perfect sense. I hadn’t thought about fades.
RichardT
Postby MOF » Sun Apr 11, 2021 7:39 pm
I think you’re confusing the 64 bit internal resolution and the 24bit audio.
Ideally your audio should be at 24bit and whatever sample rate you’ve chosen then dithered (and maybe rate converted) to 16bit 44.1khz for CD standard audio.
If you’re not exporting to CD format there’s no need for dither. MP3 formats are automatically converted from 24bit. The 64bit is for all the mathematical handling of data, such as reducing rounding errors as I understand it.
MOF
Postby The Elf » Sun Apr 11, 2021 7:41 pm
It doesn't matter what Cubase is doing internally (that's where the 64-bit comes in) - that's just the internal processing. When you create a new Project in Cubase you set the 'native' format for the Project and it is this that you need to refer to when considering dithering.
Postby Hugh Robjohns » Sun Apr 11, 2021 7:52 pm
There is some extra confusion around the 64-bit float format...
With 32-bit float the mantissa is 24 bits long, so assuming your final mix doesn't exceed 0dBFS there is no word-length reduction in producing a 24-bit fixed-point output, so technically, no redithering is necessary.... But in practice it won't do any harm to add it and at least it guarantees a consistent noise floor when fading to/from digital black.
With 64-bit float, the mantissa is obviously longer, so dithering to 24-bit fixed-point is necessary. The only question is whether Cubase (and other Daws) take care of it automatically, or not.
In practice, it wouldn't matter if you dithered any way. The noise floor would rise to -138dBFS... But that's still 10dB lower than the best D-A I've ever measured...
Postby CS70 » Sun Apr 11, 2021 7:53 pm
If what you bounce is below 0dBFS in the 24 bit full scale, no.
double (or "float64") numbers can represent signed integers between 2^-53 and 2^53 precisely. 24 bit samples are integers between 0 and 2^24 (i.e. individual distinct values that can be accepted or theoretically produced by a 24 bit D/A or A/D converter). So, once a properly coded mixing engine has done its job into a bus and the bus is below 0 dBFS (where the full scale is for 24 bits words) all values in that bus will fit in the 24 bit range without any need of approximation (incidentally, single precision floats - i.e. 32 bits floating point - can also represent the integers up to 2^24 precisely... only just. So it's the same also for mixing engines using "float" instead of "double", aka 32 bit floating point instead of 64).
In other words, "double" has space for way more integers than needed to completely cover a 24 bits integers space; "float" has just enough.
It's different when you cut the number of bits in an integer representation: in that case your target integer number space is much smaller, therefore large sets of different 24 bits integer numbers are forced into the same 16 bit integer number. Dither is a way to choose the best representative one (alternatively, you can simply think of truncation, and how to select the best approximation).
Postby MOF » Sun Apr 11, 2021 8:02 pm
Hugh and CS70, is the 64bit value something that has to be set in Cubase?
I thought floating and fixed point values were something set by the program coders.
I have Logic X , I know of no setting other than ticking 24bit to replace the standard 16bit rate.
MOF
Postby CS70 » Sun Apr 11, 2021 8:07 pm
MOF wrote:Hugh and CS70, is the 64bit value something that has to be set in Cubase?
Not an expert about Cubase, but I would be surprised if it were possible - it would mean switching between two different mixing engines. :) As you say, a mixing engine is coded and compiled in a certain way (e.g. declaring "float" or "double" in C/C++ as types of the numbers under calculation - aka single or double floating point).
It's usually set, and the only difference is the amount of additional "headroom" over 0dbFS that you get when moving data (i.e. calculating) between buses (and potentially the size of error in the calculation, but properly coded engines use well-behaved algorithms so it's not a big difference at all).
Postby MOF » Sun Apr 11, 2021 8:20 pm
Thanks CS70, that’s what I thought.
MOF
Postby RichardT » Sun Apr 11, 2021 10:01 pm
The Elf wrote:It doesn't matter what Cubase is doing internally (that's where the 64-bit comes in) - that's just the internal processing. When you create a new Project in Cubase you set the 'native' format for the Project and it is this that you need to refer to when considering dithering.
That’s the recording bit depth? As soon as you apply gain changes or any processing to that channel, though, the signal is going to be at 32 or 64 bit float, irrespective of the recording bit depth.
RichardT
Postby RichardT » Sun Apr 11, 2021 10:04 pm
Hugh Robjohns wrote:There is some extra confusion around the 64-bit float format...
Cubase doesn’t dither automatically. I use Pro-L to do it.
RichardT
Postby RichardT » Sun Apr 11, 2021 10:06 pm
Yes in Cubase, it’s possible to choose whether the audio engine works at 32 or 64 bit float.
RichardT
Postby CS70 » Sun Apr 11, 2021 10:14 pm
I stand corrected. Fun. Guess it may help a little with performance and RAM usage.
Postby MOF » Sun Apr 11, 2021 11:09 pm
I presume that’s on the PC to match the plugins, all modern Macs run at 64bit and support for 32bit was dropped a while ago.
MOF
