Disappearing synth pad in mono - any tips?
Re: Disappearing synth pad in mono - any tips?
Postby Hugh Robjohns » Fri Jun 11, 2021 2:29 pm
MarkOne wrote:On the left channel you cut every even band and on the right channel you cut every odd band, and then make up the overall gain.
Yes, this can work with a mono or not-too-wide stereo signal, but all those interacting filters can affect the sound quality too. It's a variation on a standard fake-stereo technique.
Postby Kwackman » Fri Jun 11, 2021 2:38 pm
There’s a plug-in that makes the fake widening process very easy. I’m not at my computer, but I think it’s called “Wider” and is made by Infected Mushroom and I believe it is free.
Edit.. back at computer now..
Here's a link, and it is still a free plug-in!
https://polyversemusic.com/products/wider/
Kwackman
Postby Martin Walker » Fri Jun 11, 2021 5:14 pm
Spot on Kwackman!
According to Infected Mushroom:
"Thanks to Wider’s one-of-a-kind all pass and comb filtering algorithm, a natural sounding stereo image is created from a mono channel, without compromising the phase between the sides! Instead, Wider cancels itself out when summed to mono, so the original signal is left intact.
Wider can be used to increase the stereo image of any mono signal up to 200% of full stereo for an extra wide, exaggerated effect."
Postby Murray B » Fri Jun 11, 2021 8:52 pm
Martin Walker wrote:Spot on Kwackman!
Definitely going to investigate this - sounds like just the ticket :clap: Thank you
Murray B
Postby Martin Walker » Sat Jun 12, 2021 6:26 pm
Murray B wrote:Definitely going to investigate this - sounds like just the ticket :clap: Thank you
Glad Kwackman and I could help! :thumbup:
Just be aware that it's intended for turn MONO sources into stereo ones, and not primarily to make already stereo sources wider - I downloaded it as a freebie and tried it out, but it's rare that I'd want to turn mono into stereo (my mono sources tend to either get mono or stereo effects on them, or just a little EQ and reverb, which places them in the stereo picture.
When I want to make something wider in the mix, it's invariably a stereo sound that I want to get out to the edges of the stereo image, beyond everything else, for dramatic effect. Apart from this special case, most of the time I'm far more likely to REDUCE the stereo width of a stereo sound so it doesn't take up so much real estate in the mix.
