This is a one-of-a-kind, beast of a compressor, that is up to the standards of one of the greatest producers of the moment, Koen Heldens – a multi-platinum, award-winning mix engineer, producer and sound enthusiast.
The KH-COMP1 is the best levelling amplifier that Black Rooster Audio has developed to date.
Get KH-COMP1 now for only $39.99 – limited time offer, don’t miss out!
Deal page: https://audioplugin.deals/deal-2
Deal expires on January 31st, 2021
KEY FEATURES
4 DETECTOR MODES – HILBERT/PEAK/VINTAGE/RMS
The KH-COMP1 Compressor offers incredible versatility for shaping the envelope that drives this unit – for broad or precise capturing of the sidechain level. The 4 detector modes allow for the most flexibility with time parameters and precise threshold control. The Hilbert detector is a 90-degree phase shifter, that will show the signal’s exact envelope, without any distortion or overshoots. Forget about true peak, this is the real deal!
INVERTIBLE SC FILTER
The sidechain signal can be trimmed perfectly using the 2-band invertible filter. Both the low and high ends can be processed according to your needs, which will allow for more control with ducking, pumping effects and de-essing. With inverting the filter, you are able to surgically cut out the mids. With the “listen” option, you can double-check your SC filter settings, before it will be handled by the envelope detector.
BLENDED STEREO-LINK
Blending dual mono to stereo is very helpful when you need detailed control over the relation between the stereo channels and their processing.
KNEE PARAMETER
The knee parameter smoothes out the compression effect beautifully, for a seamless result. If you’re aiming for a harsher effect, just let your signal brush over the hard edge.
SSE2 OPTIMIZED CODE
DSP operations are pipelined using the SSE2 instruction set. This ensures a high-performance operation despite its very complex computations.
ZERO LATENCY
The KH-COMP1 is a zero-latency compressor that does not require sample delay compensation, making it ideal for real-time monitoring or live environments.
HIGHDPI/RETINA SUPPORT
The user interfaces support high pixel density on both Windows and Mac OS systems, giving you the most enjoyable user experience on high DPI displays. Please refer to your DAW manual to learn whether it is HighDPI compatible if you’re working on Windows.
SYSTEM REQUIREMENTS
MINIMUM SYSTEM REQUIREMENTS (MAC)
- SSE2 compatible processor (Intel Core CPU recommended)
- 1GB of RAM
- Mac OSX 10.9 or newer
- VST, AU or AAX compatible host (64bit)
- Display resolution of 1280×1024 pixels or more
- 1GB of RAM
- Windows 7 or newer
- VST or AAX compatible host
https://youtu.be/F3BOzHh-YRE
https://soundcloud.com/user-688579952/sets/kh-comp1-original-levelling-amplifier-by-black-rooster-audio
