Create Aggregate Device?
Page 1 of 1
PostPosted: Fri Apr 26, 2019 11:18 am
by james090
Its been a while since I did this, but can anyone tell me how to create an Aggregate Device on iMac with Built in output and Soundflower?
I use Ableton to record to Twisted Wave Audio editor live, and use Soundflower. All works fine except that with Ableton using Soundflower output and TW using Soundflower input, i cannot hear what i'm recording??
In TW I have selected "play through recording" but this only monitors and plays 'aloud' the recording when the record button is pressed/recording!
So i think I have to make an Aggregate device?
I have done this using both Soundflower and my Built in output but still no sound when used out on Ableton and in on TW?
I did use to use SoundFlower BED which took care of this but not sure its still compatible or being made for Hi-Sierra (me) and above?
Re: Create Aggregate Device?
PostPosted: Fri Apr 26, 2019 11:25 am
by james090
UPDATE : scrap everything I've said above, as I have now found the latest SoundFlowerBed hidden and buried away on a site.
This looks like SoundFlowerBed 2.0.0 which is from 2014? but not sure if theres a more updated recent version if anyone knows?
It seems to be working ok, but just wanted to check on any updates :)
PostPosted: Mon Jun 03, 2019 2:19 am
by braindead3xl
Look like this addresses the question of Mojave compatibility, even though the main extension hasn't been updated since 2014:
https://github.com/mattingalls/Soundflo ... /tag/2.0b2
I'm sure you've seen this too which also does the same thing:
https://rogueamoeba.com/loopback/
