Hi Folks,
I had to install a new HDD on my system and I went with Catalina.
Not wanting to pay waves $240 for the Waves Update Plan, I came across this article.
https://denivel.blogspot.com/2019/12/ho ... macos.html
I was just wondering if anyone here had tried this type of approach or if it looks suspect.
Might this be a solution?
How to install Waves v9 plugin on macOS Catalina
• Page 1 of 1
- dbfs
- Regular
dbfs
Re: How to install Waves v9 plugin on macOS Catalina
It's only a solution if it works. ;)
All it's really doing is changing the files that tell the installer whether your OS qualifies for installing it or not - it doesn't say anything about whether those plugin versions do actually work on your system.
If you want to try, give it a try. Make backups before you start.
desmond - Jedi Poster
Hi Desmond,
I backed up and tried it and it worked. Very happy.
This might help some other folk if they are wondering.
- dbfs
- Regular
dbfs
the link above is no longer there is there directions somewhere else?
- acousticdonk
When a page no longer exists, the first thing you should think to try is to Wayback Machine that URL.
https://web.archive.org/web/20201109041616/https://denivel.blogspot.com/2019/12/how-to-install-waves-v9-plugin-on-macos.html
