Networking but no internet
Re: Networking but no internet
Postby blinddrew » Tue Nov 12, 2019 10:42 pm
Hugh Robjohns wrote:and get into the kind of IP addressing that Drew described above
I never said a word guv! I wasn't even here!
Postby The Elf » Tue Nov 12, 2019 10:47 pm
ef37a wrote:I am sure I tried Save Link as Elf and all I got was the, er, link! Not the .pdf
Quite simply... that means you weren't clicking on the PDF file link, but most likely to a link that was taking you to where the PDF was to be found!
In Firefox, if you look at the bottom of the window when you hover over a link, Firefox will tell you what that link is - you would want something with '.pdf' at the end.
Postby Hugh Robjohns » Tue Nov 12, 2019 10:50 pm
:oops: Oops, sorry... I meant Eddy...
Postby Eddy Deegan » Wed Nov 13, 2019 2:18 am
This is turning into a bit of a mountain out of a molehill.
If you want a PC on your network not to connect to the Internet under any circumstances, just set the default gateway to be the same as the IP address of the PC. It's really that simple.
The additional stuff about manual IP configurations and configuring the DHCP settings on the router is only to prevent the configuration from resetting itself on reboot. Of course you can Take It Or Leave It but it's really trivial stuff, takes little effort to set in stone forever (or until you decide to change/revert it), doesn't require additional hardware and is a lot less hassle than setting up certain printers or cameras I could mention!
Some of my works.
Postby Eddy Deegan » Wed Nov 13, 2019 2:33 am
ef37a wrote:In fact I could uninstall Fire fox (the least worse one I have found so far!)
I cannot it seems get rid of IE 11? I don't use it much except it is the only browser I have found that does "Save Target As" which I often find useful. I suppose W10 will deny me that?
Uninstalling Firefox does not (and I think it's safe to say never will) get rid of IE but that's moot because you really shouldn't be using IE anyway. Even Microsoft say so, and only provide it for 'compatibility' purposes.
The only explanation I can think of to account for what you're saying would be if you'd previously assigned Firefox as the default application to open links, and after uninstalling it it may not have reverted that default back to IE.
Windows 10 will certainly not deny you the ability to right click and 'save link/target as...' (in whatever format the browser of choice presents that option). I do it all the time :)
Some of my works.
Postby ef37a » Wed Nov 13, 2019 7:44 am
Sorry Eddy, didn't mean things to get into Civil Engineering!
I don't use IE except when FF throws a wobbly (and why does it update SO fekkin' often? )
I do get in a mess with PCs though. Only a day or so ago I got so hissed off with Oath adverts and them crashing in that I tried an ad blocker. I then recieved a very polite message from SOS that this was not good for them so I went into Options and changed 'something' . Did not stop the blocker or the message.
I then did a Restore to several hours before these events. Could not then log onto the internet at all! Reversed the Restore. Phew! Internet back but with blocker of course. Eventually found out how to stop it.
I shall content myself with pulling plugs when the time comes.
Postby The Elf » Wed Nov 13, 2019 10:48 am
ef37a wrote:I don't use IE except when FF throws a wobbly (and why does it update SO fekkin' often? )
Because browser attacks are updated so often! ;)
Postby Hugh Robjohns » Wed Nov 13, 2019 11:12 am
Eddy Deegan wrote:...you really shouldn't be using IE anyway.
I suspect Dave is referring to IE generically when he really means the default browser in Win 10, which is 'Edge', of course. The very similar icon means a lot of people still think of it as IE.
Postby ef37a » Wed Nov 13, 2019 11:33 am
I don't have W10 Hugh..yet. I have used Edge a tiny bit on my son's laptop and found it dreadful!
Postby wireman » Wed Nov 13, 2019 7:49 pm
Eddy Deegan wrote:This is turning into a bit of a mountain out of a molehill.
You need to be careful that the router does not give out the IP address you set manually on a computer to another device. Using high numbers in the range is probably going to avoid this in any case without any configuration.
wireman
Postby Eddy Deegan » Wed Nov 13, 2019 9:46 pm
I completely agree, that's why I wrote how to configure the DHCP leases on the router in my original post, but high numbers would probably be safe enough :clap: :thumbup:
Some of my works.
Postby ef37a » Thu Nov 14, 2019 12:38 pm
Quite: like so much of technology, easy for them as knows.
In anycase I would be loathe to hack my TT router because if I did bugger up I doubt TT would be very useful and by definition I would have no internet.
