Polysix Rebuild
Re: Polysix Rebuild
Postby nickle15 » Fri Apr 23, 2021 3:22 pm
jjlonbass wrote:Which microcontroller is missing? There are 2 - one, a 8049, is the "key assigner" and the other, a 8048, is the "programmer".
Both are mask programmed i.e. the software is hard-wired into the chip - there is no separate PROM. This means that you need the exact correct 8049 or 8048 part containing the correct software. Any old 8049 or 8048 won't work.
I suspect that these will be very difficult to find.
It's the 8049 that's missing. I was suspicious of how easy it was to find one - but now I know why. Again - your advice/direction is very helpful!
nickle15
Re: Polysix Rebuild
Postby rockydennis » Fri Apr 23, 2021 4:53 pm
nickle15 wrote:It's the 8049 that's missing. I was suspicious of how easy it was to find one - but now I know why. Again - your advice/direction is very helpful!
Taking a quick look online, I do see one site selling the 8049 for the Polysix for 30 Euros.
Here's a site with firmware code for various synths available for free, including the Polysix. I'm guessing the 8748 and 8749 which have eprom and are programmable, and are from the same family can be substituted for the 8048 and 8049 but don't quote me on that.
https://dbwbp.com/index.php/9-misc/37-synth-eprom-dumps
Here's someone replacing the 8049 for the Polysix with Arduino with the code made available.
http://synthhacker.blogspot.com/2013/03/polysix-replacing-8049-key-assigner.html
rockydennis
Re: Polysix Rebuild
Postby nickle15 » Fri Apr 23, 2021 5:28 pm
Excellent - thanks for adding this guidance!
nickle15
Re: Polysix Rebuild
Postby blinddrew » Fri Apr 23, 2021 6:49 pm
The level of expert knowledge that is freely given on this site never ceases to amaze me. :clap: :clap: :clap:
Re: Polysix Rebuild
Postby nickle15 » Fri Apr 23, 2021 7:19 pm
blinddrew wrote:The level of expert knowledge that is freely given on this site never ceases to amaze me. :clap: :clap: :clap:
Amen! :thumbup:
nickle15
Re: Polysix Rebuild
Postby rockydennis » Fri Apr 23, 2021 7:50 pm
Maybe replacing the 8049 with Arduino is the way to go -
"As many of you know, I made some pretty substantial modifications to my Korg Polysix. One of the biggest changes was to replace the keybed to enable aftertouch. To make this happen, I had to replace the Polysix's Key Assigner with an Arduino. It was a lot of work, but once I made the core hardware modifications, I found that I was able to add lots of features to the Polysix, such as: aftertouch and portamento, more interesting detuning for unison mode, a poly-unison mode, a Moog-like single-trigger mode, and a sustain pedal. All of these modifications were effected through software changes on the Arduino."
http://synthhacker.blogspot.com/2014/03/polysix-sharing-my-arduino-code.html
rockydennis
Re: Polysix Rebuild
Postby BJG145 » Fri Apr 23, 2021 8:29 pm
That's hardcore. Respect.
Re: Polysix Rebuild
Postby Folderol » Fri Apr 23, 2021 8:59 pm
I'd like to know how the guy got hold of a Fatar poly aftertouch keybed.
Oh, and did he have to remortgage the house.
Yes. I am that Linux nut.
Re: Polysix Rebuild
Postby The Elf » Sat Apr 24, 2021 10:36 am
Folderol wrote:I'd like to know how the guy got hold of a Fatar poly aftertouch keybed.
I've often been told that they don't do one!
Re: Polysix Rebuild
Postby Hugh Robjohns » Sat Apr 24, 2021 10:43 am
They certainly don't have one listed in their current line up.
They make plenty of keybeds with monophonic (channel) aftertouch, though -- and that's what the Arduino guy used to provide channel aftertouch in his Polysix, basically replicating the mod wheel functions from the keyboard pressure.
Re: Polysix Rebuild
Postby Folderol » Sat Apr 24, 2021 1:29 pm
I pretty much thought that was the case, but had half a hope I might have been looking in the wrong place.
