Standard chord notation
Re: Standard chord notation
Postby Wurlitzer » Tue Sep 05, 2006 11:32 pm
feline1 wrote:But let's be clear: if you are using an instrument that's stuck in equal temperament, it really is meaningless to worry about which enharmonic equivalent note-name to use. In reality, you cannot have either of them!
I disagree.
The point about using the correct note-names for a chord rather than their enharmonic equivalents is not just that they sound different (in which respect you're right - on equal tempered instruments they don't). It's that they make more sense, making the tonal and harmonic structure of the music clear to the person reading it.
This operates firstly in respect of individual chords. In most kinds of harmony in western music these are built up in 3rds. If you're using that kind of harmony, and you keep returning to say a dominant 7th chord G-B-D-F, then on one occasion you want to alter it by flattening the fifth, it makes sense to write it G-B-Db-F. The eye immediately sees that it is the same chord, but with a flat in front of it - the immediate visual impression matches the aural impression. If on the other hand you were to write G-B-C#-F, then the eye would be immediately thrown by the second from B-C# and the fourth from C#-F, and think it's some kind of inversion of something else.
Secondly, the correct spelling of accidentals gives a clearer impression of the sense of voice leading and progession from one chord to the next. Say in the example above, one wanted to resolve the chromatic note onto the diatonic one, rather than sustaining it for the full duration of the chord, then it WOULD make sense to use the C#, thus:
F.........
C#...D....
B.........
G.........
A musician's eye tend to read in "chunks", so would still see the overall sense of a G7 chord, and the visual upward movement from the C# to the D would, again, reflect what the ear hears. It's also important that in this case the D belongs to the chord whereas the C# is foreign to it - so it makes sense that the "look" of the chord is made to add up only at the resolution.
You may think this is pedantry, but I can tell you that these things make a difference for example to a pianist or keyboard player sight reading a piece in a session or trying to learn and understand a piece in depth (or even to players of purely melodic instruments, in some cases). For an orchestral score, they are absolutely essential to allow the conductor to follow and internally hear the harmony easily.
One can always say that technically it doesn't make any difference, but music is not an abstract technical science. It's something that interacts with human psychology, in real time. In this respect it certainly does make a difference.
Finally, if someone is composing music in the classical way, actually writing it down and giving it to musicians to play, then I'd say there's a real problem from the composer's OWN pont of view if they don't see any difference in writing a C# or a Db. It means they don't have sufficient awareness of what that note is doing in relation to the other notes of the composition - what function it serves within its chord, and where it is going in the voice leading. Answering those questions and answering how to spell the note go hand in hand.
Wurlitzer
Postby windbag » Thu Sep 07, 2006 10:14 am
Sure, there are rules, but as in music engraving, the 'rules' can profitably be considered 'guidelines' on occasion. The acid test is making it clear to the musician so you get the result you want. For example, in music notation, extremely chromatic passages are often better notated in sharps going up and flats going down. Nothing to do with enharmonics, simply it's quicker to read, say, G, G sharp, A rather than G, A flat, A natural. But a 'genuine' scale should be notated so that you get seven different note names, even if it means double flats or sharps. By my reckoning, G harmonic minor would be G, A, Bb, C, D, Eb, F#, G. Liekwise, some chords look much clearer one way than another, which may or may not be theoretically correct. There are times when Eb and F# look right, others when Eb and Gb look better. Usually it turns out that the theory is 'better', but not invariably. Judgment is needed.
windbag
Postby Daniel Davis » Wed Sep 05, 2007 12:30 pm
Just to clarify - inversions are decided by the lowest sounding note - and any other repositioning of notes are referred to as voicings.
If you play in a group with say a guitar and a bass guitar then any "inversion" the guitarist plays is just a voicing. the real inversion is decided by the bass player.
Equally the guitarist can play simpler(or just other) chords where required. e.g if the guitarist plays Em and the bass plays a C# it is a C#m7. Assuming there are other part to cover the gaps you can often get away (or even improve) your voicings by leaving out notes. The power chord is just one example of this.
Daniel Davis
Postby Daniel Davis » Wed Sep 05, 2007 12:47 pm
David Etheridge wrote:Hi folks,
here's a standard system of chord notation taken from Sammy Nestico's book 'The Complete Arranger'. Having a standardised version of chord shorthand means less chance of confusion on sessions and gigs. I beleive that this version is the standard form used by all the top arrangers (Mr. Nestico is currently one of the major guys), so it's useful to know this. He got it from 'Standardised Chord Symbol Notation' by Cark Brandt and Clinton Roemer (pub. Roerick Music co, USA)
Here we go:
Major chords will be indicated thus: C (and not Cmaj or ma).
Sixth chords: C6 (not C (A) (addA) or similar).
Seventh chords with the flattened seventh: C7 (not C add Bb).
Minor chords: Cm (rather than Cmin, C- or similar).
Minor 7ths: Cm7 (not C-7, min7th or similar)
Major 7ths: Cmaj7 or Cma7 (not CM7, or C with a triangle, although some people use the latter).
9ths work in the same way as 7ths (not Cmaj7+9, add D or other confusing stuff).
Aug 7ths with a #5: C+7 (not C7+, C7 (#5) or C7+5).
Aug 9ths : C+9 as for aug 7ths.
Thirteenths: C13 (and not C7 (13), C7+6, C9 add A, etc).
Diminished chords: Co; the o is a superscript placed next to the top half of the C but I can't do that on this computer! (not C-, Cdim, C7o, etc).
Six nine chords: C6/9 (not C2/6, C13 (no7) or C6 add D).
Seventh with a flat 5 chord: C7(b5) (not C7-5, C7#4, C7(5b)).
Half diminished chords-a minor 7ths with a flat 5: Cmi7(b5), although you'll find some folks use a o with a line through it, like the phase reverse sign on your mixing desk (but avoid things like Cmi7-5 and Cmi7 5b).
Seventh with a flat ninth: C7(b9). (Avoid C9b, Cb9, C9-, C(add Db)).
Minor with a major 7th: Cmi(ma7). (Not Cmi add B, Cmi+B, C-7.
Raised ninths: C7(#9) (rather than C7(+9), C+9, C7(b3) or C9+).
Sus chords: C7sus (not C7(sus4), C7 (add F), C7 (alt 4th), C7 (+4) or C7 #3)).
Augmented 11th chords can be C9(#11), (not C+11, C11+, C11#, C9+11, or C9 (b12)).
Note that the + sign is used to indicate augmented, rather than a substitute for a #. Some musos use the dash (-) to mean minor, dim, or even a flat. No wonder you can get confused :?
Try not to use lower case letters on your parts for other players: a badly written 'mi' could be read as 'mj': is it major or minor? Is it real or is it Memorex (hands up all those who remember that advert :D)
MA is never used by itself, only in Ma7 or Ma9. Just write the chord name alone for the major chord (eg: Cm/ C). I once had a fine time on a gig with a rhythm guitarist who couldn't work out major and minor chords, to chaotic effect on some tunes! :headbang:
So that's it for the present. Even with this shorthand, sometimes you've got no option than to write C13 #11 b9 b5!
:roll:
Best wishes,
Dave
Well a funny thing happens when you move beyond triads - the same set of notes can be interpreted in more ways. e.g. take the notes CEGA you have either a C6 or an Am7 chord.
From an ensemble player's point of view this means you can choose other possibilities to play (often simplifying your parts or adding variety).
As you add more notes the possibilities increase, until with 7 note chords they can be anything - so-called pan diatonic harmony. Holst uses this in the Planets suite - but never wrote another decent piece. perhaps because...
From a harmonic point of view the strength of chords with more than 3 notes is that they gain flexibility and can perform more than one harmonic role. This is particulary good when you repeat a section using the same chord to take you in a different harmonic direction. On the down side as you add roles each is weakened , predictability dissappears, and functional harmony distroyed.
Daniel Davis
Postby Knut Skaarberg » Fri Aug 22, 2008 3:14 pm
Daniel Davis wrote:Just to clarify - inversions are decided by the lowest sounding note - and any other repositioning of notes are referred to as voicings.
An Em with C# bass would be a C#m7(b5), wouldn't it?
Anyway, does anyone here know what's the standard notation for open voicings (no 3rd) such as C-D-G, C-G, C-G-Bb, C-D-F-G etc? What about quarter chords (4th, but no 3rd or 5th) such as C-F-Bb?
BTW, it's a great pleasure to meet all of you! ;)
Knut Skaarberg
All the best, Knut Skaarberg
Postby onesecondglance » Fri Aug 22, 2008 3:25 pm
wouldn't C-D-G be Csus2? and similarly C-D-F-G Csus2/4? i'm sure i've seen these written this way in guitar scores.
onesecondglance
Postby Wurlitzer » Fri Aug 22, 2008 3:49 pm
Knut Skaarberg wrote:An Em with C# bass would be a C#m7(b5), wouldn't it?
Well spotted!
One can't really say "standard" here, because the chords themselves are not standard. The open fifth I've sometimes seen notated as "5". Thus C-G alone = "C5"
C-G-Bb I'm not sure. I'd probably just write "C7(no 3rd)". Alternatively you could write Gm/C, if you felt relaxed about the player adding a D if he wants.
The others you describe are various combinations of 4ths/5ths and 2nds/7ths. As such, if you juggle the notes a bit you can usually reduce them to some kind of sus4, or 7sus4 chord, and then just use a slash to indicate the bass note. Thus:
C-D-G = Gsus4/C
C-D-F-G = G7sus4/C
C-F-Bb = Fsus4/C
But if you're really thinking in 4ths, as opposed to writing within a conventional framework of 3rds but in a "4thy" way - then you might be better off notating the part at least in guide tones. Write a chord voicing upwards in 4ths, in semibreves, and then just tell the player to use whatever rhythm feels right to it.
In modal jazz, it's quite common for pianists to gravitate towards 4ths and 2nds because they capture the harmonically "floating" sound better and don't push things in as clear a direction as 3rds. So you might write "Cm11", and depending on the feel and style, the player might voice it upwards: C-F-Bb-Eb, omitting the G and making 4ths out of everything else. Some of Bill Evans's playing on "Kind Of Blue", and similar music of the period, is a case in point.
But this is a very inexact science and it relies on people sharing a common set of unspoken understandings, or being able to walk over to the piano, stab a few 4ths and say "a bit more like that!" or whatever...
Wurlitzer
Postby Knut Skaarberg » Fri Aug 22, 2008 4:22 pm
Thanks for the thorough reply!
I agree in principle on could write C-F-Bb as Fsus4/C, but that indicate it resolves to F/C, wouldn't it? As a piano player I would tend to play with diffent positions of the "double quarter" chords over a C bass, such as
G-C-F
A-D-G
C-F-Bb
D-G-C
and so on. Maybe that's a bit on the edge of what standard chord notation is useful for. :D
Knut Skaarberg
Postby onesecondglance » Fri Aug 22, 2008 4:58 pm
Wurlitzer wrote:... if you juggle the notes a bit you can usually reduce them to some kind of sus4, or 7sus4 chord, and then just use a slash to indicate the bass note. Thus:
C-D-G = Gsus4/C
hi Wurlitzer, just out of interest, C-D-G can sound (in some contexts) more "C" to me than "G", hence i would say (as above) that that is Csus2 and not an inversion of Gsus4. is there a reason it should be Gsus4/C or is this just another way of seeing the "same" chord? just for my future reference... (i.e. is calling it "sus2" bad form, as technically you can only have sus4? or something?)
onesecondglance
Postby Wurlitzer » Fri Aug 22, 2008 6:45 pm
Knut Skaarberg wrote:I agree in principle on could write C-F-Bb as Fsus4/C, but that indicate it resolves to F/C, wouldn't it?
Not really. Sus4 chords in jazz aren't presumed to "resolve" the way suspended 4ths are in classical harmony. The 4th is just a static entity that can go wherever it likes, usually.
That's kind of what I meant about unspoken assumptions.
G-C-F
A-D-G
C-F-Bb
D-G-C
Indeed, and that's exactly the kind of thing I meant where it might make more sense just to write out the voicings.
Chord symbols were originally derived from tonal harmony, and were not purely a technical description of the chords in isolation. eg Dm7 - G7 - Cmaj7 doesn't ONLY tell you what notes to use above each root, it also tells you that it's a II - V - I in C.
As harmony becomes less and less functional in modern jazz, you can start to approach a point where the chord symbols might accurately describe each chord, but what they appear to be saying about the chord function is completely misleading. eg your progression above is basically a set of parallel 4ths within the mixolydian mode on C. The bass is C all the way through, and that bass is harmonically independent from the chords (apart from the fact that it generates the mode they belong to). As such, calling those chords F this or G that might be technically correct, but doesn't actually give one a very clear idea into what is going on.
But then in this kind of style the harmony is usually pretty freely improvised anyway (although sometimes within strict constraints of mode). Often the chord symbol only changes when the mode does, which might only be once every 8 bars or so. But within that period, you'll hear the piano and bass exploring the kinds of things you describe here.
Unfortunately there is not yet a settled and agreed language in which to describe things any more precisely than that!
Wurlitzer
Postby Wurlitzer » Fri Aug 22, 2008 6:50 pm
onesecondglance wrote:hi Wurlitzer, just out of interest, C-D-G can sound (in some contexts) more "C" to me than "G", hence i would say (as above) that that is Csus2 and not an inversion of Gsus4. is there a reason it should be Gsus4/C or is this just another way of seeing the "same" chord? just for my future reference... (i.e. is calling it "sus2" bad form, as technically you can only have sus4? or something?)
No, it can just as rightly be described as Csus2, that's a perfectly accepted notation. And if you're thinking of it with a C root, that probably makes more sense.
Wurlitzer
Postby David Etheridge » Sat Aug 23, 2008 3:39 pm
Knut Skaarberg wrote:Thanks for the thorough reply!
I agree in principle on could write C-F-Bb as Fsus4/C, but that indicate it resolves to F/C, wouldn't it? As a piano player I would tend to play with different positions of the "double quarter" chords over a C bass, such as
G-C-F
A-D-G
C-F-Bb
D-G-C
Hi Knut,
if you did this with C in the bass, the chords could be annotated as:
(C) G C F : Csus4
(C) A D G: C6/9 (no 3rd)
(C) C F Bb: C7sus
(C) D G C : C2.
and to my ears C D G sounds simply like a C2.
Hope this helps,
:lol:
David Etheridge
Ataris which keep on going, 28 hardware synths. Still recording to tape.
Postby onesecondglance » Mon Aug 25, 2008 6:24 pm
excellent. always nice to know you've not made an idiotic remark in public :D
onesecondglance
Postby Tony D » Wed Dec 10, 2008 11:18 am
Hello David.
I read your review a while ago of the BASSIX Electric Bass.
I currently play an ARIA SB1 Electric Upright. It is OK ish at low volume but when I take it up a bit it goes into the fretless bass guitar sounding.
Your review of the BASSIX made it sound that maybe it would be worth investing in. Would you recommend the BASSIX.??
Regards
Tony Dunmore
Tony D
Postby IvanSC » Wed Dec 10, 2008 6:05 pm
Tony D wrote:Hello David.
Regards
Tony Dunmore
Not sure why you are in Music Theory with this but a few words from me on MY experience with EUB`s.
PLayed a Clevinger in the USA back in er 83 or 84.
The full size one was excellent, the Baby sounded like a fretless bass guitar.
Fast forward to last year.
Picked up a pretty crappy ol dupright and have been slowly making headway on it.
In the meantime I have played two or three more EUB`s, all of them short scale, as this BASSIX appears to be.
They don`tplay like an upright and they don`t sound like one either.
If BASSIX do a full (40-42") scale EUB, that might be a horse of a different color, but for the time being I am looking into a pickup for my doghouse.
Eager posters please note: An AFFORDABLE pickup for my upright.
IvanSC
Two bottles of Corona lemon and lime,  please!
