what fuse do I need, yamaha emx66m
Re: what fuse do I need, yamaha emx66m
Postby James Perrett » Wed Oct 21, 2020 9:51 pm
Hugh Robjohns wrote:
James Perrett wrote:I haven't gone through the rest of the circuit to find out why they need such large values but presumably there's a large inrush current on power up or high peak currents.
From page 26 of the user manual:
For European Model
Purchaser/User Information specified in EN55103-1 and EN55103-2.
Inrush Current: 85A
Conformed Environment: E1, E2, E3 and E4
I wonder how long that current lasts? If it is more than 10ms the fuse should blow (although the fuse is only rated at a max interrupt current of 40A). There's around 32000uF of smoothing capacitors in there which will certainly draw a fair amount of current while charging up.
