Build project - resonator guitar from recycled bits
Re: Build project - resonator guitar from recycled bits
Postby Wonks » Sat Feb 09, 2019 1:14 pm
You could simply cut the body in half from side to side, then add a 4-5mm section to make the body longer. :D
Postby adrian_k » Sat Feb 09, 2019 5:01 pm
Yeah simple ;)
Of course since the neck is not glued to the body I could pack out the tail end of the perch pole which will push the fingerboard away from the bridge. I’ll need to make up the resulting gap between the body and heel, but I guess in the worst case it’s an option...
adrian_k
getting better all the time..
Postby blinddrew » Sat Feb 09, 2019 5:20 pm
It's a blues guitar, it's not supposed to be in tune... ;)
Postby Wonks » Sat Feb 09, 2019 5:22 pm
Are you able to rig up a tail piece, put a saddle in, fit the two E tuners, put some strings on and check the intonation? Whilst measurement is OK, there's nothing like the empirical test method.
Postby adrian_k » Sat Feb 09, 2019 8:12 pm
blinddrew wrote:It's a blues guitar, it's not supposed to be in tune... ;)
And with my slide technique it’s irrelevant anyway! :tongue:
@wonks yes I agree, I’ll only really find out when I rig up a temporary saddle
adrian_k
Users browsing this forum: Martin Walker
