My Top 5 DAW Features & Functions
• Page 2 of 5 • 1, 2, 3, 4, 5
Reaper: My Top 5 DAW Features & Functions
1. Freeze tracks
My PC is getting on a bit and on more complex tracks it starts to struggle a bit. Being able to freeze a track and free up extra processing power, knowing that it's trivial to unfreeze and make future edits, is a hugely useful feature. Way better than having to bounce a track.
2. Plug-ins and their configuration
The range of free-with-the-system options is huge and the quality is very high. It'll handle all manner of different formats (including old 32-bit versions). Virtually every plug-in parameter is automatable, and can be assigned to midi hardware controllers.
3. File / import handling
Video, audio, different sample rates… just lob them into the project and it translates everything to the project defaults and away you go. No fuss, no additional steps, no manual configuration required.
4. Small footprint and low CPU usage
Reaper has a very small download size and can run with a very low CPU overhead. It also can be made a 'portable install', all of which means I can put a copy onto my aging laptop and still comfortably record 16 tracks of audio without running into any issues.
5. Everything is configurable
Well, maybe not quite everything, but the depth of options under the hood is huge. Just a right-click away are a set of options that vary from the 'use every project' to 'Interesting, but I can't imagine why anyone would ever need to use that'. Configure your channels, your meters, your routing, your tracks, your automation lanes, your fader ranges, your colour schemes, your hardware, etc. etc. You can really set things up to your personal workflow.
P.S. a lot of this mirrors some of the stuff James said upthread, but I suspect that will happen a lot as this develops. :)
P.P.S. In response to CC's question above, yep, Reaper allows you to create project templates but also instrument templates as well. So if I'm recording electric bass (for example), I have a template that loads a blank instrument channel, a distorted channel to blend in some harmonics, a parallel compression channel, and a pre-reverb feed. All routings, plugins, formats etc set up and ready to go. Arguably this could replace number 5 above, but they could be seen as facets of the same thing...
blinddrew - Jedi Poster
Re: My Top 5 DAW Features & Functions
Thanks CC. I edited your post to include Logic in the title.
If someone is not primarily a DAW user, then I'm not hoping for a contribution from that person. ;-)
Templates?
Yes, pretty standard feature nowadays on most DAWs, though what isn't necessarily standard is the ability to save, import and exchange mix/console channel 'strips' -- a fab new feature in Studio One that I've wanted for a while, but have been using workarounds, like saving sessions (S1 calls these 'songs') after deleting unwanted tracks/channels and retaining only the plug-in configs I wanted to build a library of.
Templates?
Forum Admin - Moderator
- Location: A studio deep in the fenlands of Cambridgeshire, UK
SEARCH SOS 10,911 articles: www.soundonsound.com/search
FREE Full Issue PDF Digital Mag: https://sosm.ag/FreePDF
Cakewalk by Bandlab/Sonar: My Top 5 DAW Features & Functions
Giving it a go. DAW is Cakewalk Bandlab/Sonar
1. the prochannel EQ. Instant high pass on every track that needs it, and when used for musical reasons the EQ is really good.
2, The support for comping. It makes getting thru takes and pick the best bits... well, not a breeze (it's still boring) but not too much painful.
3. Nice sequencer and midi editor. I use midi and virtual instruments very little but when I do, I want to get result quickly without having to read a manual. Mouse in hand, even I move stuff around and set velocities quickly and efficiently.
4. Flawless support for 32 bit plugins. There's some I like and am very familiar with and there's zero technical reasons for having to move to 64 bit at plugin level. Cakewalk's implementation of bitbridge is rock solid.
5. Keyboard shortcuts for absolutely everything. There's gazillions and I definitely don't know even 1 per cent, but if I find myself doing something many times ("select -> none", for example) you can be certain there's a shortcut for it (Ctrl+Shift+A)
CS70 - Jedi Poster
Reaper & Cubase: My Top 5 DAW Features & Functions
I use Cubase and Reaper. There are too many features to list, and we can take the basics for granted. So instead of my 'top' five, here are 'five of the best' features of each...
Reaper
1. Parameter modulation. Wow. Every DAW should have this.
2. Mouse modifiers — way more powerful than keystrokes alone. Every DAW should have this.
3. Scripting support — there's a whole community of people who will adapt this DAW to meet your needs! Every DAW... ah, you get the picture.
4. The routing flexibility. Drag and drop sends. Sends and receives on every track. Folder-busses. Up to 64 channels inside every stereo track. Routing matrix for each and every plug-in.
5. Prolific updates, with new features and bug fixes pretty much every month or two.
I've not even talked about the tiny download size, the stability, the CPU efficiency, the various grouping/linking options, the ability to run it off a pen drive... etc etc.
Cubase
1. The Chord Track, and its integration with both Variaudio and MIDI. Elegant and helpful.
2. Quadrafuzz V2. Utterly brilliant plug-in (even if the default presets aren't!)
3. Groove Agent's Acoustic Agent, the drum editor and drum maps.
4. The Control Room.
5. Automatic vocal alignment (even if Revoice Pro is better, it's good, and this is bloody brilliant to have inside your DAW).
Reaper
Cubase
- Matt Houghton
- Frequent Poster
SOS Reviews Editor
Logic: My Top 5 DAW Features & Functions
I use 2% of Logic's capabilities and features, I'd be very glad to hear about other user's favourite bits, best tips and tricks. Great post.
1. Cycle record and subsequent re-stitching of takes.
2. One click to turn a recording into an Apple loop.
3. Loving the eq range - channel eq low shelves on every track and the others are great for tone shaping.
Can't think of anything jumping out that other daws don't have but like I say I'm aware I only use a fraction of what it can do. Looking forward to learning some more, hopefully from this thread.
kinglouis - Regular
Reason: My Top 5 DAW Features & Functions
I use Reason and three features stand out for me :
1. The mixer, the layout of which, I believe, is modelled on an SSL desk. For an old school git like me having the Mixer View instantly accessible and in such a straightforward way makes life a lot easier. New tracks are added automatically and everything is clearly labelled, every channel has EQ and compressors just where you would expect them, with decent default effects automatically "wired" to the FX sends and returns, with the ability to accept additional supplementary FX.
2. The comping facilities are comprehensive, intuitive and effective.
3. The third feature I would highlight is one which I have found useful when trying to show youngsters looking to learn how to create recordings for themselves. It is the Reason "gimmick" whereby shift and tab used in Rack View reverses the rack units and shows the (virtual) cabling between units and mixer channels, enbling the connections to be modified or supplemented. This invariably provokes the reaction "cool, just like a proper studio" and helps create enthusiasm to learn to use the tools available.
Hope this helps.
Regards, John
Hope this helps.
Regards, John
John Egan - Regular
Thanks for the tips - great stuff.
In truth, I think we're all in the same boat when it comes to only using a fraction of our DAW ( except desmond ;-) maybe).
I'm sure if I didn't say "thank you PreSonus" under my breath so much already when using Studio One, I'd be a massive convert to Reaper. I've always liked flexibility in software programs, and S1 Pro lets me achieve the same goal in multiple ways (as does Reaper from what I hear, and other DAWs).
And those Macros... being able to automate tasks and map anything to a custom keystroke is bliss. Again, Cubase is powerful here too, but I've watched plenty of YT videos and it never seems as simple and quick to set up as Studio One's implementation.
Macros can help with many tasks if you plan ahead, and this short tutorial video from Marcus Huyskens demonstrates how to use them to gain stage Virtual Instruments.
https://marcus-huyskens-music.com/mh-music-blog/quick-tip-gain-staging-virtual-instruments-in-studio-one-4-using-macros
ADD YOUR DAW NAME HERE: My Top 5 DAW Features & Functions
Just a quick reminder to add your DAW name(s) as a Prefix to the Reply subject title, so skim-readers can find the DAW they use and read your tips/features.
I've edited them thus far. ;-)
1. Drum Edit Page.
I've used this since it was in Pro-24. The diamond icon for the hit makes it easy to see if a note is lagging or before the beat, better (IMHO) than a line or box. Maybe it's because I started with a TR707? Once a drum map is set up, creating patterns is easy.
2. Cycle Record with the corresponding comp tools.
3. User defined keyboard short cuts.
Everyone uses Cubase differently, so being able to change the keyboard short cuts to what makes my workflow easier is very useful.
4. Reliablilty.
Like all DAW's, reliability is almost the norm now. I did have my first huff with Cubase recently, it took a re-install to sort it. Other than that, it's been rock solid for me for many years on Atari and various Macs. YMMV
5. VST plug ins.
I know all DAW's have them (or their own versions), but Steinberg invented the VST ( I think) and there are now more EQs, Compressors etc. than we can cope with along with new stuff that isn't possible on hardware.
4. Reliablilty.
5. VST plug ins.
Kwackman - Frequent Poster
I use more than 1 DAW... for exactly the reason that each DAW has unique strengths. :ugeek:
1. Chord Tools (Pads)
- be it the chord assistant, track, pads - everything related to working with chords - I love being able to keep track of musical ideas without having to write stuff down outside of the DAW. Coupled with the ability to jam within different scales makes this my goto feature for writing.
2. Arranger Track
Other DAWs have something similar but the flexibility to create different versions of my rough work is tops. I tend to work in parts and assembling the ideas in itself can be a creative journey which quickly can become confusing unless one has a map - visual aid - which the AT is...
3.MIDI Device Manager
I still use a few hardware synths - so this is a no brainer - other DAWS don't care about patch names for hardware synths
4. VariAudio
The quickest way to fix and to modify a recorded melody line - which before the latest update, was also the least messy way since Melodyne required more file management .
5. Expression Maps
I cannot imagine a realistic sampled instrument without a bunch of articulations, and keeping track of which is triggered where in the song quickly became irksome ... along came EM - changed my life.
2. Arranger Track
4. VariAudio
5. Expression Maps
C.LYDE - Regular
Adobe Audition: My Top 5 DAW Features & Functions
Adobe Audition:
1 Noise reduction features. Audition has a number of ways to get rid of unwanted noise, and they're all good. If you can't clean it it up in Audition, that's pretty much a clear indication it needs to be re-recorded.
2 Appearance. For a start, Audition often looks better than other DAWs because it limits one's ability to go crazy with jarring color combos. Also, easily configurable screen appearance. It's really easy to make things visible/invisible and move stuff around.
3 I find editing to be very easy and quick.
4 I forget what the feature's called, but I have my template set up so that at a keystroke only a particular group is displayed - the drum group, for instance. It makes navigating a mix super fast and everything's zoomed in/out the way I like it.
5 CD View. I still burn CDs, and Audition has a CD creation screen that makes it really easy to set up and burn CDs.
PS: It might be interesting also to list the ONE feature you'd like to see added to your DAW of choice. Here - I'll start: (puts on grumpy voice) MIDI recording and editing capability!
awjoe - Frequent Poster (Level2)
Fringe member of the Party Pooper People's Party
1. VariAudio.
2. Fade handles.
3. Ability to warp tempo map to audio.
4. Audio editing.
5. MIDI.
2. Fade handles.
4. Audio editing.
5. MIDI.
The Elf - Jedi Poster
Hello! Mr Party-Pooper here! :wave:
I'd be surprised if the majority of DAW users are markedly different to me in that:
I learnt from various sources what a DAW was;
I decided I could make my life easier/more creative by using one;
I saw one advertised* that seemed to fit/to do what I was looking for;
I bought it; learnt to do the things I need to do; used it. Stuck with it; upgraded as new features became available.
* For others that will have been a recommendation from a forum consensus or having someone they knew recommend/demo one.
Most of us are happy with what we've got. We've not done a tour of alternatives... like many things in life, we like what we know and are nowhere near unhappy enough or persuaded by other features to have to learn a new DAW and the way it functions.
Is the way 'A' does something better than 'B'? I don't know and am not really bothered. I work with what I've got...
- Mike Stranks
- Jedi Poster
I’m going to make a new sign for my studio:
STOP THINKING - MAKE MUSIC!
:blush: :blush: :blush:
http://www.bickerton.co.nz
Re:Cubase: My Top 5 DAW Features & Functions
I really have little to no experience of any other DAW than Cubase, so I guess familiarity & the fact that it does everything I need (which isn't much) makes me stick with it. I have no idea how it compares to other DAW's but I'm guessing from this thread there's a huge overlap. If I had more time to spare I'd probably give Reaper another try. My five top features would probably be;
1: Variaudio
2: Quadrafuzz V2 (Stupid name, awesome plug-in)
3: The Chord Track
4: Generate Harmony voices
5: Track Lanes (which initially I hated)
1: Variaudio
3: The Chord Track
- Dynamic Mike
Re: Reason: My Top 5 DAW Features & Functions
John Egan wrote:I use Reason and three features stand out for me :
If you have any curiosity in this area, check out Harrison Mixbus. It's laid out like a desk, and many people love it for that reason. Plus it sounds great.
This thread's been an eye-opener for me. I assumed, like I do with most things, that most people are way better at DAWs than I am. But it seems that most people don't know a lot about any DAW other than the one they've used since they were born. Maybe another question to add to the survey is 'how many DAWs are you more or less familiar with?'
'Cause if you only know one DAW, you're not in a great position to know what your top features and functions are.
awjoe wrote:This thread's been an eye-opener for me. I assumed, like I do with most things, that most people are way better at DAWS than I am. But it seems that most people don't know a lot about any DAW other than the one they've used since they were born.
That's because, as this thread shows, the differences are minimal, and mostly cosmetic.
I may have missed something, but the only stuff that's a little bit DAW-specific are Cubases' automatic harmony and chord tools and my mention of ProChannel (which however is nothing more than a pre-loaded set of plugins). And it's just a little specific... there's plugins for automatic harmony and chord tools.
Harrison is a bit off because its audio engine has built-in distortion and crosstalk. I have it but it wasn't enough of a thing for me to shift.
So, so long it works, a DAW is a DAW, just like a drill is a drill. You pick a top shelf one and that's about all the attention it needs.
CS70 - Jedi Poster
REASON
I'm not sure that it matters whether you have the best DAW with the top features (whatever that is). The music matters. I think it's worth asking if there is anything that your current DAW will not support sensibly that a different DAW would enable.
I have in the past used Sonar as my DAW, but was put off by a change in appearance and style and so moved to Reason. At that time I also tried Live, Tracktion and Cubase, but they didn't grab me at all. There was also Project 5 from Cakewalk, which I found interesting, but it was discontinued. Once Reason enabled recording, I was able to move to it completely, having already started to use its MIDI instruments alongside Sonar, using Rewire. I have seen no reason to change since.
Regards, John
awjoe wrote:'Cause if you only know one DAW, you're not in a great position to know what your top features and functions are.
Regards, John
John Egan - Regular
I tried it and liked it initially. but lack of stability was a big issue for me.
I sometimes export stereo mixes from Cubase and do the master bus processing in Harrison Mixbus, but that's all I'm using it for these days.
ore_terra - Frequent Poster
