Thinking ahead perfect PA
Re: Thinking ahead perfect PA
Postby gsc1ugs » Fri Oct 18, 2019 11:31 am
Got use to doing that when i had no bins... sometimes do it for low speaking lyrics, live is different from that promo. Thxs :thumbup:
gsc1ugs
Postby Sam Spoons » Fri Oct 18, 2019 12:01 pm
Yes that's the one I remember, nice :clap:
Cupping the mic affects the frequency response and directionality (if you block the vents at the back of the capsule you change the pattern into omni with all the feedback issues that can produce).
Postby shufflebeat » Fri Oct 18, 2019 4:47 pm
gsc1ugs wrote:Great words.... BUT.... at this stage im looking at something i can manage and and good rig with easy enough add ons and a graphic will suffice for now. Thanks for all your input.
I feel you may have inadvertently pre-derailed the conversation with the word "perfect". If you were to substitute "appropriate" we might have been more focussed on your needs rather than dealing with the fact that a "perfect" option doesn't exist without an actual human making real time choices.
Do you already have a mixer?
Are the rooms adjacent?
EQ will not solve phase issues, it may mask them temporarily until your audience arrive.
Once you have the main FOH sorted a pair of Yamaha DXRs on a delayed aux if appropriate would raise few complaints from normal punters (SOS folks might tut a little).
shufflebeat
"Dancing Queen - feel the heat from the tangerine, ooh yeah!"
Postby Sam Spoons » Fri Oct 18, 2019 5:31 pm
OK, back to the original question.
You'll struggle to find a scalable system that will cover all the bases, the nearest I can think of with a decent budget would be 4 x DZR10s and a couple of DXS15 subs. 2 x tops for small gigs and add a sub or two and the extra tops as delay satellites* as they get bigger. You'll need a digital mixer (any will do the job but I have 2 x X32s, an XR12 and a Mackie DL1608, the Mackie is the easiest to use)
* place them part way down the room and delay them by 1ms per foot. They won't work as well placed side by side in a conventional room but if you run one pair about 3dB lower than the other it helps keep comb filtering effects down. In an odd shaped room firing the tops into different areas will work ok.
Postby gsc1ugs » Fri Oct 18, 2019 6:00 pm
Your right, im doomed, just setting up now
In a room hard floored, how the hell can i sound check with noone in
gsc1ugs
Postby gsc1ugs » Fri Oct 18, 2019 6:45 pm
I do remember something years a called i think an autographic equaliser, dont know anything about it but i believe it sorted the graphic to the room but to who’s taste?
gsc1ugs
Postby gsc1ugs » Fri Oct 18, 2019 7:21 pm
Sam Spoons wrote:OK, back to the original question.
Thats 4 x £915
2 x £1587
:ooo:
gsc1ugs
Postby shufflebeat » Fri Oct 18, 2019 10:44 pm
Thats 4 x £915
2 x £1587
:ooo:
To be fair, this is quite an expensive game if you want quality/ease of use/reliability.
Your goal is good and the advice here is well intended.
shufflebeat
Postby Sam Spoons » Sat Oct 19, 2019 8:54 am
Thats 4 x £915
2 x £1587
:ooo:
Considering the iD24 rig you linked to is £6.5k for only 4 boxes I'd say that was terrific value. And it'll be much louder.
If you fancy L'Acoustics kit a single 112P (now discontinued) FR cab would set you back £6k+ and it doesn't go as loud as a DZR10.
Good, cheap & loud, pick 2.......
Postby gsc1ugs » Sat Oct 19, 2019 10:17 am
I know the advice is excellent reason im on and about to start a new thread :crazy:
I will try my best find that rig 2nd hand. I dont mind bashes and bruises. Thxs all.
gsc1ugs
Postby Sam Spoons » Sat Oct 19, 2019 11:07 am
How many 200+ gigs do you do a year*? If it's not many I'd still consider hiring in a big rig (and possibly a sound guy) for the big gigs.
*Two DZR10/12s and a single sub will cover anything small with ease (and possible larger),
Postby gsc1ugs » Sat Oct 19, 2019 11:38 am
Im on it with the DZR10's/12
gsc1ugs
Postby dickiefunk » Fri Oct 25, 2019 9:02 am
It would be worth checking out secondhand Nexo PS10’s and L500/600 subs. You will need th amp + controller but I’ve seen these go for between £3000-£4000 and they are seriously loud!
dickiefunk
http://www.richardpenrose.com
Postby gsc1ugs » Fri Oct 25, 2019 9:44 am
When you say “loud” i dont want deaf’n people i want warm thick room filling clarity or is that same thing?
gsc1ugs
