Orchestral reverb spacing
Re: Orchestral reverb spacing
Postby Hugh Robjohns » Wed Oct 30, 2019 3:07 pm
I guess it depends on what orchestral layout you're trying to model.... ;)
Really, I understand you want it to 'be right' but there is no 'right' because every orchestra is different and their seating plans change with different venues and different repertoires.
So just fiddle with the panning until it sounds right to you... but as the Elf says, the image width tends to decrease the further away things are...
Postby Moroccomoose » Wed Oct 30, 2019 3:41 pm
Thanks, that settles the argument in my mind! I was torn between visualising panning as an angle in the sonic field, or as a distance to the right or left from the listening position. By visualising as an angle, no need to push things further L or R as they radiate away from the listening position.
Right - now to set up all the articulations :headbang: :beamup:
Cheers!
Moroccomoose
Postby Peterlkarl » Thu Oct 31, 2019 1:46 am
I always set up 3-4 reverbs in DP, though not usually to simulate an orchestral performance environment. If I'm understanding what you're trying to, you could just set up 4 stereo Aux sends and returns, each with similar Proverb impulse responses employed, but varying pre-delay settings, (and maybe progressively longer decay times). Have a ball!
Peterlkarl
Postby The Elf » Thu Oct 31, 2019 8:56 am
Peterlkarl wrote:I always set up 3-4 reverbs in DP, though not usually to simulate an orchestral performance environment. If I'm understanding what you're trying to, you could just set up 4 stereo Aux sends and returns, each with similar Proverb impulse responses employed, but varying pre-delay settings, (and maybe progressively longer decay times). Have a ball!
As I explained above, one reverb produces a less cluttered, less phasey and more convicing result that simply adding the same reverb multiple times.
Try it yourself and see.
Postby Zukan » Thu Oct 31, 2019 9:39 am
Good technique Elf. I like.
Zukan
Postby tadghostal » Thu Oct 31, 2019 11:55 am
This is an excellent source of info! Thanks Elf and co. I've learned a lot just by reading this and trying it out. I'm going to incorporate it into my newbie work and see how it pans out
tadghostal
Postby Martin Walker » Thu Oct 31, 2019 5:33 pm
tadghostal wrote:This is an excellent source of info! Thanks Elf and co. I've learned a lot just by reading this and trying it out. I'm going to incorporate it into my newbie work and see how it pans out
Of course you get extra SOS forum points for managing to slip in a pun there tadhostal :clap:
Postby ManFromGlass » Fri Nov 01, 2019 12:28 pm
Pantastic ;)
Postby Wonks » Fri Nov 01, 2019 12:49 pm
Don't fader way.
Postby ManFromGlass » Sun Nov 03, 2019 1:16 pm
the constitution of an aux
Postby Gone To Lunch » Wed Nov 06, 2019 10:20 pm
Indeed I did try this and that is exactly what I found, it is less cluttered and more convincing.
But I also grouped some of the sends thus, because it is such a PITA to use microscopic send controls in DP, I send individual instruments to a shared reverb aux bus thus
Strings - Vln1, Vln2, Vla, Vc, DB
WindsL - flute, oboe etc
WindsR- clarinets
Perc - all of them
Horns
Trumpets
Tbones
Piano, Mallets remain individual
However the indiv instruments are panned individually, they just share a common reverb
The reverb sends from the aux bus are varied to fake distance thus
B - Perc = 0
BM - Brass -4
FM - Winds -8
F - Strings - 12
Keys and Mallets in between BM & FM - 6
This is the best so far, but of course I am now drowning in the hell of infinite editing opportunities without a deadline to meet.
Gone To Lunch
http://www.gonetolunchmusic.com/
Postby Sam Spoons » Wed Nov 06, 2019 11:40 pm
That looks as if you are delaying the strings and not the percussion, surely the percussion, who are at the front of the orchestra, would need more delay than the percussion who are at the back?
Postby Wonks » Thu Nov 07, 2019 9:45 am
Sam Spoons wrote:That looks as if you are delaying the strings and not the percussion, surely the percussion, who are at the front of the orchestra, would need more delay than the percussion who are at the back?
Percussion front and back? Obviously a severe case of 'more cowbell'.
Postby Sam Spoons » Thu Nov 07, 2019 11:13 am
Bugger :blush: , changed my mind on the phrasing but buggered up my edit (in my defence it was well past beer-o'clock).......
Percussion at back, long delay, strings at front short or no delay.
Postby jimjazzdad » Thu Nov 07, 2019 12:25 pm
WindsR- clarinets
Perc - all of them
Horns
Trumpets
Tbones
B - Perc = 0
BM - Brass -4
FM - Winds -8
F - Strings - 12
Wow. Reading this makes my small but orderly brain hurt! This is exactly why I like to capture orchestra as simply as possible - an MS pair or maybe spaced omnis - and add a bit of Bricasti dust on the stereo bus as required. A well placed coincident pair will always give a more realistic image with depth than any amount of hocus pocus in post... (just my humble opinion; carry on!)
jimjazzdad
Halifax, NS, CANADA
PreviousNext
