Cassette Tapes are back?
Page 1 of 5
PostPosted: Fri Oct 12, 2018 4:42 pm
by twotoedsloth
I thought you folks might find this interesting:
https://www.recordingthemasters.com/2018/10/11/audio-cassettes-are-produced-again/
Strange that they are Type 1 cassettes... I'm not all that familiar with cassettes, as they were largely replaced by CD-Rs when I was studying, but aren't Type 2 (chromium dioxide?) or Type 4 (metal?) cassettes vastly superior?
The price is reasonable, $30 for ten. Will DAT have a similar renaissance? I kept my prized DA30 against this possibility...
Re: Cassette Tapes are back?
PostPosted: Fri Oct 12, 2018 4:55 pm
I like this "We manufacture and distribute audio products for professional recording engineers and audiophiles, providing superior recording and sound playback qualities." from their website..... :bouncy:
You'd be better off buying these though https://www.wilko.com/en-uk/maxell-ur90-audio-cassette-5pk/p/0455057?nst=0&gclid=EAIaIQobChMI8PeM96GB3gIVq73tCh2S_AItEAQYAiABEgIky_D_BwE&gclsrc=aw.ds
Nowt wrong with DAT (I still have a DA-20) it was the same 'quality' as early CDs. But, I believe, the AD and DA convertors back then were not as good as modern ones.
PostPosted: Fri Oct 12, 2018 7:23 pm
by James Perrett
I understand that no-one makes type 2 or type 4 tapes any longer but the high frequencies on those tapes are reputed to self erase after a while which plays havoc with noise reduction systems if they've been used.
There have certainly been quite a few cassette releases recently - Kylie Minogue being one of the more well known artists to use the format.
PostPosted: Sat Oct 13, 2018 6:46 am
by ef37a
Nowt wrong with type 1 ferric either!
TDK AD was a terrific T1 tape when set up correctly but it did need a high bias. Properly set up most of the top ferric brands could equal the performance of vinyl when used with Dolby B. Even without it the tape was fine for most low dynamic range "pop", especially in a car!
I am sure it was JLHood that produced a series of articles (W.World?) about building a cassette recorder (oh yes! "Men" were men then!) and he concluded that even type 1 ferric should use the T2 70 microsecond EQ regime? This was I think due to the advances in tape formulations that had come about by then.
Another advantage is that today, any decent machine you get will have the higher recording and bias capability needed for chrome and so it would be easy to set up T1 cassettes to run T2 EQ.
T2 HF "self erasure"? How would one know unless you played one in a magged up deck?
PostPosted: Sat Oct 13, 2018 8:33 am
by Humble Bee
I love cassette tape! I think...
PostPosted: Sat Oct 13, 2018 8:44 am
by ef37a
http://www.keith-snook.info/wireless-wo ... 20deck.pdf
Even if you don't want to build one (who would today?!) the article gives a very good insight into cassette recording technology.
Even then I personally thought the use of the 741 was scraping the economy barrel a bit low! But then I don't think the NE5534/2 existed in 76? Maybe in TI's lab?
PostPosted: Sat Oct 13, 2018 10:47 am
I've got a feeling the precursor to the NE5534 was the TDA1034, and I think that probably was available in 75/76. TDA1034s were certainly used in the early Quad 44 preamp disc board which was introduced in 1979 and probably in development for a year or so before that, and I doubt they would have used brand new, unproven ICs...
PostPosted: Sat Oct 13, 2018 11:26 am
by nathanscribe
This might be a daft question, but what happens if you use the 'wrong' bias setting for tape? For example, if the machine doesn't allow a selection.
PostPosted: Sat Oct 13, 2018 11:33 am
Degraded frequency response and more noise and distortion, basically.
PostPosted: Sat Oct 13, 2018 11:34 am
Not much in real terms, the tonal balance will be less accurate than if you use the correct settings for the tape but you won't damage anything and the tape will still play back.
PostPosted: Sat Oct 13, 2018 11:36 am
by blinddrew
Harumph. If ever there was a medium that should have been consigned to the dustbin of history...
:grumpyface:
PostPosted: Sat Oct 13, 2018 11:57 am
by ef37a
blinddrew wrote:Harumph. If ever there was a medium that should have been consigned to the dustbin of history...
:grumpyface:
Cannot agree. I had a Denon with 3 heads, dual loop capstans ( v low W&F) CPU tape optimization, Dolby B and HX. Using TDK SA it was VERY hard to tell a copy of a CD from the original, even TDK AD and even the better Sony t1 ferrics were very close and certainly good enough for general daily use, dubbing vinyl, recording FM broadcasts*.
The really "big lie" today is the mad vinyl revival! Scraping a tiny jewel along a trough of copolymer al la Edison! Yes, I head some superb sounds from direct cut disc (SME, V15ll, 405, big Castle Acoustics) but pressings? And how long do they stay click/dust free? Assuming you get a good one to start with! Self shows some of the design effort needed to make a decent disc replay pre amp. The technology and cost involved in disc cutting is astronomical and the results worse than I got with the Denon!
If we are "doing " revivals? I would love a "linear" coded minidisc recorder. 20 minutes or so per disc would do me for a bit of Bach or Floyd! As they are I think they are better than most MP3?
*Twas said in the day that a live prom stereo broadcast was THE best sound quality you could get given a top line receiver and reception 10/20. Sadly I could never aspire to either (Northampton stereo "birdies")
PostPosted: Sat Oct 13, 2018 12:11 pm
by blinddrew
I had a couple of nice cassette decks (and a very nice, last-generation panasonic walkman) and agree that with appropriate care you could get a decent recording.
But any device that requires a bic biro as part of your long term maintenance kit is flawed.
Hopefully as networks speed up and memory continues its ever decreasing cost we'll soon be dumping MP3 and everything will just be wav files.
PostPosted: Sat Oct 13, 2018 1:48 pm
by Ariosto
Personally I never found cassette tapes to be much good, and very liable to break or get tangled up. Reel to reel on a good machine was excellent especially on two track quarter inch tape at 15ips.
But nothing comes up to digital in my opinion - 24bit wave files.
Interesting programme on Radio 4 Extra today on recording and it's history, even if very long winded ...
PostPosted: Sat Oct 13, 2018 1:52 pm
by ManFromGlass
blinddrew wrote:But any device that requires a bic biro as part of your long term maintenance kit is flawed
I know. Try to find an original biro these days . . . . . .
On the serious, well semi, serious side - after setting up a turntable et al I realized I was too lazy to stand up every 18 minutes to flip the lp over. At least with cassettes certain decks could play side 2 after side 1 automatically. I have a vague memory of side 2 played this way often sounded like crap, where turning the cassette over to play side 2 sounded fine.
