Recording an Orchestra - Cold
Page 1 of 5
PostPosted: Thu Sep 19, 2019 5:33 pm
by jimh76
So there is a possibility that I could be recording and orchestra for a concert (looks like about 10-20 piece) they are doing in a church, but would only be able to set up about 1 hour before and will not get chance to do test recordings, set levels etc.
My brief is that I'm not to interfere with the look of the stage too much and I can't block out performers with mic stands etc.
My mics are'nt top of the range, so I've listed them below:
Rode nt1 (original grey)
Rode NT 1a
Rode M3
SE x1a
2 x Red5 Audio RV4
1 x SE 1a
other dynamics like SM57s x 3 etc, but assume I wouldn't be using these.
Tascam DSP32SD (8 inputs)
My thoughts are as follows, and just want to welcome any other opinions.
Set up the 2 Rode NT mics on the front left side and front right side facing backwards towards the middle of the stage, about 6-7 feet up in the air on stands. I would use these with ART tubeMP preamps into 1 & 2 (my quietest mics).
Set a stereo bar with the 2 RV4s in the x/y setup in the front middle of the stage facing backwards to where I assume the conductor will stand. As per the brief I can't be too obtrusive so thought the max height would be about chest high (not ideal I know). The RV4s are not matched by the way. Inputs 3&4
Setup a general stereo mic set up on the piano (se1a on bass strings & SE X1 on the upper strings?). Inputs 5&6.
Audience mic needed for the applause? If so, mono or stereo?
I'm basically intending to use the first piece they do as a level setting exercise, ready for piece 2.
I'm doing this for free, so there's no real pressure, but I want them to want me back to perhaps record future performances, so want to do well.
Any thoughts welcome.
Cheers,
Jim.
Re: Recording an Orchestra - Cold
PostPosted: Thu Sep 19, 2019 6:29 pm
by jimh76
Sorry. Just realised I posted this in the wrong section. Not sure how to move it though.
Moderators?
PostPosted: Thu Sep 19, 2019 6:39 pm
by Forum Admin
jimh76 wrote:Sorry. Just realised I posted this in the wrong section. Not sure how to move it though.
Moderators?
No problemo - only Mods can move posts. I've moved it now to the Recording: Gear & Techniques forum for you
PostPosted: Thu Sep 19, 2019 6:42 pm
by jimh76
Thanks for that.
Jim
PostPosted: Thu Sep 19, 2019 8:25 pm
by blinddrew
Hmmm. Am I right in thinking you've got no fig-8 microphones in that little collection?
PostPosted: Thu Sep 19, 2019 8:58 pm
by jimh76
Correct. All cardiod. I think the main compromise will be the rv4s as the aren't the quietest of mics and will only really be at performer head height.
PostPosted: Thu Sep 19, 2019 9:05 pm
by blinddrew
If I read the specs right the RVs only go down to 50Hz - not sure if that's a genuine -3dB or something more optimistic so you might find your set up is a bit bass-light.
PostPosted: Thu Sep 19, 2019 9:31 pm
by Mike Stranks
Two big issues...
1) You don't have two of any of your mics save the RVs which aren't that suited for this task.
2) The restrictions on mic stands.
Would you be able to put in one thin tall stand? If you could get approval for that you could use a standard non-boon stand with one of these extenders (https://www.thomann.de/gb/km_2000530055.htm?M_184862_0_fb120ee9-bc48-4fe2-a6c7-e83959669769=undefined) on top. Relatively thin and unobtrusive.
Then as you've not got anything approaching good matched mics I'd just record in mono - stand behind conductor - and use the NT1. Anything else and you'll have a compromised recording.
PostPosted: Thu Sep 19, 2019 9:42 pm
by Sam Spoons
That's what I would do as well with your existing mic locker :thumbup: If you had a fig 8 mic or a pair of something then stereo becomes an option but you haven't so take Mikes advice.
PostPosted: Thu Sep 19, 2019 10:21 pm
by Wonks
Whereabouts are you? If there are other SOS forum members close, I'm sure someone would be happy to lend a matched pair or a fig-8 mic for mid/sides recording.
PostPosted: Thu Sep 19, 2019 10:50 pm
by Aural Reject
It’s a compromise situation, but if you’re absolutely limited to the mics on your list look at using the RV4s in a near coincident configuration like ORTF or NOS.
The height of the stand may provide a problem with front-back balance. If you’ve a way of getting them higher without using a stand, have a look at that.
PostPosted: Thu Sep 19, 2019 11:14 pm
by jimh76
Cheers for the input peeps.
Would any of my setup sound better than a handheld recorder like the zoom models?
Would it sound awful to the layman, or is it just to us sound engineers?
PostPosted: Fri Sep 20, 2019 7:38 am
by Arpangel
As someone else said, where are you? I have stands cables etc I could lend
It should be possible to do this with the mic's you have, but ideally, you need two "suitable" mic's of the same make, at the least. From what you say about placement, it sounds as though this is a performance rather than a "recording session" first and foremost, priorities would be a lot different, and also quallity expectations.
I would have a word, in the most diplomatic way, to explain that unless you're able to have free reign, within reason, on mic placement, then compromises will have to be made on quality. It depends on how important this is to you, but sometimes these things can be more hassle than they are worth.
Also a sound check is absolutely necessary, and a seperate room for monitoring, on this basis alone I'd walk away, I know others will say different, but honestly, it's you that has to educate people sometimes, it's not a one way street.
And yes, a handy recorder correctly placed on a single stand may do the job, it all depends on what their expectations are.
I'm sure there are Grammy award wining engineers out there that could turn in a spectacular recordings in these circumstances, but.....
PostPosted: Fri Sep 20, 2019 8:54 am
by Arpangel
PS
If you had one figure 8, you could make an M&S pair as the main mic's, and the two mic's don't have to be from the same manufacturer, and you have a few spot mic's left if you need them.
PostPosted: Fri Sep 20, 2019 9:36 am
by Mike Stranks
Arpangel wrote:Also a sound check is absolutely necessary, and a seperate room for monitoring, on this basis alone I'd walk away, I know others will say different, but honestly, it's you that has to educate people sometimes, it's not a one way street.
Well here I am, an "other who will say different". :)
I've done countless recordings of this type where the first note you hear is in the performance, and monitoring is sitting in a corner at the back wearing decent noise-attenuating headphones. And often straight to stereo...
The key inhibitors here are stand height and lack of suitable mics for stereo. I, too, would be willing to pitch up with a matched-pair of tiny mics or two and suitable stands and T-bars to help out. In this situation I'd fall-back on the four-mic Faulkner array - a life-saver when mics, stands and cables have to be kept to a minimum.
OP: I'd approach the organisers again about mic stands. They may be thinking that it'll be loads of stands as in a pop/rock setting. Explain that it'll be one vertical stand with mics well above sight-lines.
But on one thing (at least) Arpangel are agreed... sometimes if the restrictions will make your job almost impossible then you walk away. I've done it a few times and I think that Hugh has too.
