Record electric guitar with HI-Z
Postby aviorrok » Wed Sep 23, 2020 9:40 pm
Hi,
I’m trying to record my guitars with my audio interface (UR242) I turn on the Hi-Z the gain now louder but not enough. I also tried to record with my preamp (WA273) and the gain is low (lower than the UR242) why? The problem maybe on the TS cable?
(With 70% gain knob and pick the db pick is 13-12dbfs)
Thanks!
aviorrok
Re: Record electric guitar with HI-Z
Postby Ramirez » Wed Sep 23, 2020 10:10 pm
aviorrok wrote:With 70% gain knob and pick the db pick is 13-12dbfs
That’s plenty!
Ramirez
www.stiwdiosain.cymru
Postby aviorrok » Wed Sep 23, 2020 10:41 pm
That’s plenty!
12dbfs or 70% gain? I want to reach 12 with 30-40% gain knob
aviorrok
Postby ef37a » Thu Sep 24, 2020 6:24 am
aviorrok wrote:
That’s plenty!
Why? Almost does not matter how you get it there but you want your initial guitar recording at around -20dBfs (24 bit, 44.1kHz recording). If, with the guitar controls flat out the AI is giving you about that level then good on the designers. Quite a few AIs put too much gain in instrument inputs, I suppose the 'Marketing Men' insisted that 0dB fs is always possible with even the wimpiest plywood Strat. The result is, a hot humbucker will overload the front end of the interface and that does not sound nice. There was at least one famous AI maker that fell foul of this problem a few years ago.
Even recordings at -30dBfs can be digitally boosted and the only noise with be that of the guitar which, by the way will be only some 60dB below the wanted signal.....IF you are lucky!
But, if you really want to hit the DAW harder there are clean boost pedals about.
Postby Ramirez » Thu Sep 24, 2020 7:36 am
That’s plenty!
Both. You’re able to reach a decent level (perhaps a bit too hot, even) with the given gain range of the interface, so there is no problem.
Also bear in mind that a lot of preamps in interfaces suffer from ‘gain bunching’, where most of the available gain is bunched up in the gain knob’s last few degrees of travel. Taking that into account, there’s a chance that you’re at quite a bit less than 70% of the available gain, even if the knob position suggests it.
Ramirez
Postby CS70 » Thu Sep 24, 2020 7:51 am
aviorrok wrote:
That’s plenty!
Then use a high output pickup.. :)
Postby ef37a » Thu Sep 24, 2020 11:13 am
"Taking that into account, there’s a chance that you’re at quite a bit less than 70% of the available gain, even if the knob position suggests it."
Very good point Ramirez, the gain or volume control of a device, be it interface or guitar amplifier never gives a genuine relationship between angular position and electronic effect. Only very expensive, high end gear will have properly 'calibrated' controls and faders.
This is encapsulated in the famous line from the film Spinal Tap "This one goes up to eleven!"
Only a very tiny proportion of us audio geeks ever really 'got' that!
Postby Hugh Robjohns » Thu Sep 24, 2020 1:15 pm
aviorrok wrote:I’m trying to record my guitars with my audio interface (UR242) I turn on the Hi-Z the gain now louder but not enough.
Loud enough for what?
It has a different gain structure
What problem? But a TS cable is very easy to test with a cable tester or another source.
That sounds perfectly ideal to me as a tracking peak level.
