Opinions on my metal mix
Postby HonzaS » Sun Oct 18, 2020 7:12 pm
Hello everyone!
I've just gotten into recording and I need someone to take a listen to my mix. Drums are virtual. My problem is that no matter how I mix the song, I can't get vocals to sit in well afterwards. So here is a short sample of my work, thank you in advance if you decide to give it a listen and give me your opinion :D (hopefully the link works xD)
https://drive.google.com/file/d/1iVz6V6 ... v08nO/view
HonzaS
Re: Opinions on my metal mix
Postby The Elf » Sun Oct 18, 2020 9:39 pm
No, the link doesn't work.
Postby HonzaS » Sun Oct 18, 2020 9:52 pm
The Elf wrote:No, the link doesn't work.
Should be working now.
HonzaS
Postby The Elf » Sun Oct 18, 2020 10:34 pm
There's not much to go on here, especially as we never get to a vocal section with the guitars playing, but the first thing I would do is to look at reducing some of the mids in the guitars. That should make them sound more 'expensive' and also begin leaving room for the vocal. At the moment you do have a good set of wide guitars, but the ones pulled toward the centre could also drop out to leave room for the vocal, when it arrives.
Maybe a bit more bite in the kick might be good - at least where it's exposed. I'd like to hear a bit more dirt in the bass too.
I like the fact that you're sparing with reverb - that will stand you in good stead in this genre, but don't be afraid to creat big ambiences when it's needed.
It's not at all bad, though. You're getting good width in the mix, and I'm left hoping I get to hear more!
Postby HonzaS » Sun Oct 18, 2020 11:09 pm
The Elf wrote:There's not much to go on here, especially as we never get to a vocal section with the guitars playing, but the first thing I would do is to look at reducing some of the mids in the guitars. That should make them sound more 'expensive' and also begin leaving room for the vocal. At the moment you do have a good set of wide guitars, but the ones pulled toward the centre could also drop out to leave room for the vocal, when it arrives.
Thank you so much for your feedback! It really gave me a ton motivation! I've removed the up-front guitars and it really created a lot of space. Again, thank you for your time!
HonzaS
