Garageband & OS Mojave ???
PostPosted: Sat Oct 31, 2020 6:00 am
by DigitalMusicProduction
Hi
Is it possible to install garageband 10.3.5 on a Macbook Pro mid 2012 using mojave?
Re: Garageband & OS Mojave ???
PostPosted: Sat Oct 31, 2020 11:25 am
by desmond
As long as your hardware supports Mojave (it does), and GB's min requirements are at least Mojave (yes, min requirements are still High Sierra for GB 10.3.5) then I can't see there are any problems.
Why, do you suspect there might be a problem? Have you tried and something isn't working?
PostPosted: Sat Oct 31, 2020 8:41 pm
desmond wrote:Why, do you suspect there might be a problem? Have you tried and something isn't working?
I've spent the past few days amalgamating all the tech spec compatibility's for a MacBook pro mid 2012 i intend to purchase, hence the reason for posting, but if what you say is accurate, all should be fine, thanks Desmond.
PostPosted: Sat Oct 31, 2020 8:54 pm
FWIW I have GB 10.3.2 on my mid 2012 MBP. I don't use t as I prefer Reaper but on the odd occasion I have run it it has behaved as expected.
