Best Format for USB Stick, for swapping Windows and Mac?
Postby james090 » Wed Jan 31, 2018 10:11 am
Probably the most often asked question, but some online info, says different things..
And I hope this is the best place to ask here?
Im using a Windows 10 pc, to collate samples (WAV, MP3 etc) but then need to transfer to a Mac in another studio.
This will include transferring MIDI Files, WAV samples, and Ableton .asd and .als project files etc.
What is the best format to use with a frequent swappable USB stick without any pain or problems easily between W10 and Mac OS X back and forth?
So I could get a good 64Gb or 128Gb stick to move projects between the two?
Many thanks
james090
Re: Best Format for USB Stick, for swapping Windows and Mac?
Postby job » Wed Jan 31, 2018 10:34 am
ExFat worked well with Apple's previous file system. No idea about the new one. Worth a try though :thumbup:
job
Postby james090 » Wed Jan 31, 2018 10:41 am
job wrote:ExFat worked well with Apple's previous file system. No idea about the new one. Worth a try though :thumbup:
I have been told FAT32? Is this based on the same system?
james090
Postby The Korff » Wed Jan 31, 2018 11:04 am
FAT32 is compatible with both (ie. you can read from/write to it from both OS X and Windows), but it has a 2GB file-size limitation.
The Korff
Postby james090 » Wed Jan 31, 2018 11:07 am
The Korff wrote:FAT32 is compatible with both (ie. you can read from/write to it from both OS X and Windows), but it has a 2GB file-size limitation.
Thank you Korff, I was told 4GB limit, but either way 2 or 4 doesn't really matter as I won't be using files that big I don't think.. :clap:
So I just need to get a good 128Gb USB to move files between and format as FAT32, Sandisk?
james090
Postby Hugh Robjohns » Wed Jan 31, 2018 11:16 am
You need to use the ExFAT format which is compatible with both PC and Mac and doesn't suffer the 4GB limitation of FAT32 -- and yes, you could easily find yourself falling into that problem with long, high-res interleaved audio files.
This article from Laptop Magazine describes how to format the drive from a Mac or PC very clearly:
https://www.laptopmag.com/articles/form ... ws-and-mac
Postby Matt Houghton » Wed Jan 31, 2018 11:45 am
+1 for ExFAT. There's no downside compared with FAT32, which it was designed to replace, so you might as well.
If you're only using specific computers, you could alternatively install software on them to allow them to all to read NTFS (or Mac format drives for that matter). That would offer a slight advantage in that these support longer filenames (ExFAT filenames are limited to a max of 16 characters IIRC), which can sometimes be handy when working with audio. But of course if you want to use the drive in any other machines, you'd need to install software, or copy the files across (Mac can read but not write to NTFS).
Matt Houghton
SOS Reviews Editor
Postby resistorman » Wed Jan 31, 2018 7:21 pm
I’ve been using ExFat for years for just such issues. Matt, the actual limit is 255 characters: 255 UTF-16 characters, so maybe that’s where the idea originated.
http://www.ntfs.com/ntfs_vs_fat.htm
resistorman
Postby james090 » Fri Feb 02, 2018 3:52 pm
Ok great, so Ex-FAT it is..
Does this go for bigger drives, that need to be switched between Mac & PC easily? or is this just a USB drive issue?
Thanks!
james090
Postby Watchmaker » Fri Feb 02, 2018 3:54 pm
Any drive
Watchmaker
Postby Kathi F Elder » Tue Jul 30, 2019 8:48 am
If you expect to transfer files between a Windows computer and a Mac, you should decide on either FAT32 or exFAT.
Step 1: Plug the flash drive into the USB port.
Step 2: Launch a Finder window.
Step 3: Run Disk Utility.
Step 4. Choose a format for your flash drive.
Step 5. Format your flash drive.
Every time you want to permanently delete files on your USB drive, you don’t have to format it again. You can just use a reliable file shredder to conveniently erase files in a secure way.
iMac-Cleaner File Shredder does just that. You can use it to delete confidential files on your Mac, external hard drives, and SD cards as well.
Kathi F Elder
Postby FrankRaz » Fri Aug 02, 2019 7:29 am
Personally I wouldn't use a big drive with exFAT. I used to have a 3TB exFAT formatted drive that I used to use between Mac and PC. It was all fine when I was alternating between the two regularly but if I used it for a long period on PC only, the next time I used it with Mac it would take ages to mount. One day it wouldn't mount. I tried it with a PC and it was fine so I plugged it into the Mac again and left it. There was nothing wrong with it, it just took an hour to mount. Nowadays I use a couple of 500GB drives and use them as go betweens only, trying not to keep anything on them permanently and I've not had a problem since.
FrankRaz
