Hornet VU Meter MK 3 - Q) Max Peak best setting?
Postby monoboy » Sat Jun 22, 2019 11:22 pm
Hey!
By default The reference setting is on -18 which I leave as is, But with the ‘Max Peak’ setting which option is best to set in most mixing situations?
I use a lot of Analog emulation plugins, such as the ones from Waves, Ive heard that those plugins work best at -18, not sure if this means I would choose the Max Peak to be at -18, by default it’s set to -6.
Thanks ! :)
monoboy
Re: Hornet VU Meter MK 3 - Q) Max Peak best setting?
Postby Martin Walker » Sun Jun 23, 2019 9:41 pm
Hi monoboy!
That Max Peak setting sounds about right to me at -6dBFS.
A VU meter has a slow response and ignores the signal peaks (300 milliseconds of integration time). It works in a similar way to the human ear, so you should expect peaks to rise somewhat above your reference level.
I've recently been using a VU meter referenced to -18dbFS, and peaks on my music typically hover around -10dBFS, but then my stuff is dynamically smooth. Another 4dB in a more transient-laden mix sounds perfectly feasible to me.
Hope this helps!
Postby monoboy » Tue Jun 25, 2019 5:50 pm
Hi Martin,
Many thanks! Will take your suggestion on board and leave it on default -6 - much appreciated!
monoboy
Postby Martin Walker » Thu Jun 27, 2019 1:47 pm
My pleasure - let us know how you get on, and whether you find this 'Max Peak' setting works for your music in practice.
