Sonarworks Systemwide won´t "see" TotalMix inputs
Hi all. I´ve just installed Systemwide on my home laptop, and got around the fact that you also need to set it up as a monitoring effect in Reaper, as the audio coming from the DAW doesn´t stream through the "Sonarworks Virtual Device".
So, audio from Reaper: VST Sonarworks. Audio from any other software: Systemwide app. But... I was expecting my audio inputs (mics, guitar, bass) would be passed through Systemwide when Reaper is not opened, but that´s not working. If I use record monitoring in Reaper I can hear the corrected audio input, though.
Am I doing something wrong, or is it just the way it is?.
Thanks for your help.
