Something for The D.I.Y. crowd to drool over
PostPosted: Tue Jan 28, 2020 2:17 pm
by Folderol
I've just received a flyer from RS about a new completely isolated, mains PSU with built in filters with the same footprint as a standard IEC filtered chassis plug!
These are 5W units and cover the following ranges:
190-7530 3V3 @ 1A51
190-7531 5V @ 1A
190-7532 12V @ 420mA
190-7533 15V @ 333mA
190-7534 24V @ 210mA
They are all fully protected against overloads etc. have a standby mains consumption of only 75mW and come at just £11.85
My guess is that the 5V one will be in greatest demand - perfect for Arduino based projects, and also for Raspberry Pi zero.
Re: Something for The D.I.Y. crowd to drool over
PostPosted: Tue Jan 28, 2020 2:43 pm
by The Elf
PostPosted: Tue Jan 28, 2020 4:24 pm
by Wonks
No 9v one to replace wall warts though. :( A bit of a shame.
PostPosted: Tue Jan 28, 2020 5:21 pm
by Folderol
Wonks wrote:No 9v one to replace wall warts though. :( A bit of a shame.
For the lightweight kit up to approx. 30mA , use the 12V one and put a white LED in series.
Approx 3V drop and visible indication it's drawing power.
For beefier ones use a 3V zener diode in series (0.5 to 1W). If you still want the current indication, shunt that with a red LED (2v) and 56 ohm resistor.
PostPosted: Wed Jan 29, 2020 9:43 am
by DGL.
Interesting, will be interesting how good they are with audio devices as that will be their real test. Although according to the datasheet they do conform to the standards for AV devices.
https://docs.rs-online.com/60a8/0900766b81741c89.pdf
I suppose, if the price of this can be gotten down enough, with suitable power ratings then I can see this being a go to product for manufacturers that want an internal PSU but don't want to go through all the certification. as I would guess that as it is a fully enclosed device there would not need to be any mains safety certification for the device it is installed in as this PSU has no live parts accessible.
PostPosted: Wed Jan 29, 2020 10:19 am
by Wonks
Just having a 9v version would make it so much easier for everyone (who wants a 9v PSU) though.
PostPosted: Wed Jan 29, 2020 10:25 am
by Wonks
DGL. wrote:I suppose, if the price of this can be gotten down enough, with suitable power ratings then I can see this being a go to product for manufacturers that want an internal PSU but don't want to go through all the certification.
The complete assembly will always have to be tested to CE standards and certified. Which is why external PSUs make it so much easier for manufacturers as they then have two separate assemblies. Put the same PSU inside the main product and there are a lot more EMC tests/test configurations that have to be gone through.
PostPosted: Wed Jan 29, 2020 11:35 am
by Folderol
Wonks wrote:The complete assembly will always have to be tested to CE standards and certified. Which is why external PSUs make it so much easier for manufacturers as they then have two separate assemblies. Put the same PSU inside the main product and there are a lot more EMC tests/test configurations that have to be gone through.
Not necking celery.
Under some circumstances you are permitted to claim you are confident it meets the standard, and then it only requires a complete certification if there is a reasonable challenge made. With a totally sealed unit, with its own full certification and (looking through the data sheets) well exceeding standards required, such a challenge would probably get quickly thrown out.
The only proper certification needed would be for EMC, not safety - and you'd need that whatever PSU was used.
PostPosted: Wed Jan 29, 2020 3:40 pm
by ef37a
On the basis that YCPAOTPAOTT, I shall whinge that they missed a trick not providing 15-0-15 volts which would be perfect for op amp power.
Could use 24V and an op amp to get a centre rail but that compromises headroom a tad.
No nine? There is a good bet the DC will land on a PCB so just use 15V and a 7809.
PostPosted: Wed Jan 29, 2020 8:07 pm
by Martin Walker
DGL. wrote:Interesting, will be interesting how good they are with audio devices as that will be their real test. Although according to the datasheet they do conform to the standards for AV devices.
Now that's a very SLICK design :clap:
PostPosted: Thu Jan 30, 2020 12:03 am
by The Elf
I live in hope... :-|
PostPosted: Thu Jan 30, 2020 8:43 am
by Wonks
The Elf wrote:I live in hope... :-|
You need to change your location in your profile then. ;)
PostPosted: Thu Jan 30, 2020 11:50 am
by Folderol
... and each year I go to SynthFest simply from hope :thumbup:
