Superior Drummer 3 vs BFD 3
Postby Glenn Bucci » Sat Jul 14, 2018 2:39 am
I started with BFD drums, then BFD 2, and then BFD 3. Recently I purchased Superior Drummer 3. I am still learning the program, but I have to say, I don't believe you can get better sounding drums than Superior Drummer 3. Part of the reason is the studio room chosen for the project, and the other reason is George Massenburg in the drum room and behind the mixing console.
First observation: I love in SD3 than you just slide a grove to the bottom of the screen. Then you can copy or slide a verse 2 groove, pre chorus, multiple chorus, and ending grooves for the song. Soooo easy. You can adjust the length of the groove if you want to add a fill anyplace you want. BFD3 does not have this, its more like Ride beat 1, Ride beat 2, instead of Verse 1, Verse 2 option. I like the names better on SD3. It helps you find what your looking for faster and what will fit certain things on a song faster.
With BFD3 you have to have a midi controller, assign the hits to different keys, hold the key down with the loop feature on, and then switch to a different keyboard key during the song for different grooves and or fills. There were times I found it triggered too early or it won't trigger at times. The work flow of SD3 is much easer and faster.
The sound of both drum software are excellent. It seems SD3 has a more open sound. It sounds like the drum kits are on the other side of your monitor. Two minus issues; it seems you cant' dampen the drums with SD3 with a slider like you can with BFD 3. You also can't change the mic positions like you can with BFD3. However George did such a great job, not having the mic position control is not an issue.
So there are some pros and cons for both. Both have a internal mixer with effects you can add. I like on SD3 the bleed control is on the mixer on the top of each track. This makes the work flow faster than BFD3. Both have great grooves and fills. The search feature on the SD3 for a certain groove is also handy. There is also a sub kick drum fader as well as a kick in and kick out. that offers greater flexibility.
One big advantage I found with BFD 3 is the amount of grooves and fills they provide. They have a lot more than what Superior offers. On Superior Drummer 3, if you go to Jazz category, there are no groove options with a ride cymbal. If you choose Power hand Ride, Jazz and Latin grooves are grayed out. This is very disappointing.
On Superior if you choose rock, country and you choose ride, there are no verse options to choose from only Chorus, intro and fills. Granted you can use the Chorus groove for verse 1, but when the other types of styles have many verse 1, 2, etc. its disappointing again.
Now in BFD 3, there is a category; Jazz Brushes V1. In this folder there are 18 grooves and 8 fills. Next is Jazz Brushes V2, V3, Jazz Sticks V1, Jazz Sticks V2, Jazz V1, Jazz V2, Jazz Walk sticks and Smooth Jazz, and Swing Jazz. So all these category's have their own grooves and fills.
This is an example of the limited grooves in Superior vs BFD 3 and I found in each catagory of grooves, BFD 3 offered more grooves and fills. This is something to think about before making a purchase.
So for me, the work flow of Superior 3 is much better than BFD 3, and creating grooves is a lot easier. But with the limited amount of drum grooves in the different catagory's is a disapointment. Granted there are still some catagory's in Superior like Blues that have a pretty decent amount of grooves to choose from. But Funk, Jazz, and Latin are very small. Superior has no Reggae, or Samba grooves/fills at all. Hopefully Superior expands their groove/fill options in the future.
Glenn Bucci
revelationsoundstudio.com
Re: Superior Drummer 3 vs BFD 3
Postby thefruitfarmer » Sat Jul 14, 2018 5:18 pm
Great post.
I am looking at getting Superior Drummer 3 for a reggae project, amongst other things, and I prefer the look and sound of SD3 to Addictive Drums.
Not looked at BFD3 yet...
Glenn Bucci wrote:
"It seems SD3 has a more open sound. It sounds like the drum kits are on the other side of your monitor. Two minus issues; it seems you cant' dampen the drums with SD3 with a slider like you can with BFD 3. You also can't change the mic positions like you can with BFD3. However George did such a great job, not having the mic position control is not an issue."
Would it be possible to use the gate in SD3 to take the ring out of the drums?
I think they have a Transient Designer plug in as well which would probably do the trick?
Glenn Bucci wrote:
"So for me, the work flow of Superior 3 is much better than BFD 3, and creating grooves is a lot easier. But with the limited amount of drum grooves in the different catagory's is a disapointment. Granted there are still some catagory's in Superior like Blues that have a pretty decent amount of grooves to choose from. But Funk, Jazz, and Latin are very small. Superior has no Reggae, or Samba grooves/fills at all. Hopefully Superior expands their groove/fill options in the future."
I did wonder why there were no vids on youtube of SD3 reggae ....
What I would probably have to do is get the EZ Drummer adds ons, the reggae MIDI grooves https://www.timespace.com/products/toontrack-reggae-beats-midi?utm_source=Click&utm_medium=Channel&utm_campaign=Google_GB&ref=SFDR_139113279&variant=37092133578&curr=GBP&gclid=Cj0KCQjwvqbaBRCOARIsAD9s1XBzI3QSiNgv1B7pC84aQO3YHdvFBHCx09cNhj-g02fhAsA2MP9HJ28aAt-MEALw_wcBand the reggae kit https://www.timespace.com/products/toontrack-ezx-reggae.
Will have to have a proper look at BFD3, although the SD3 interface is winning at the moment and it might be worth paying the extra for the add ons.
thefruitfarmer
Postby Glenn Bucci » Sun Jul 15, 2018 3:36 am
https://www.sweetwater.com/store/detail ... -xEALw_wcB
This makes sense. Just download the type of drum grooves you would want. Too bad SD3 did not include more grooves so you wouldn't have to buy them later on. I already added Jazz, Rock, and Fusion. Much happier now.
Glenn Bucci
Postby thefruitfarmer » Fri Jul 27, 2018 11:08 am
BFD3 allows third parties to make drum kits and drumdrops has a good reggae kit, which is sold in BFD3 format for £35.
https://www.drumdrops.com/drum-samples
BFD3's own expansion called Horsepower sounds as good in demo as the EZDrummer Nashville kit.
https://www.fxpansion.com/products/bfdx/bfdexpansions/bfdhorsepower/
It is discounted from £120
BFD3 can be found for less than £200
https://www.google.co.uk/shopping/product/11579558843356167044?q=BFD3&rlz=1C1GGRV_en&biw=1600&bih=767&safe=active&ssui=on&prds=hsec:online,paur:ClkAsKraX5NB0zdSgGjx6X6gXRg5NxouHxpQDpG_NQ130rRTeJQcenEmyXp1moqZd3BTcon_8QV-puP0_xLHSYxGB5YVy5co0OgxAKtK12S0FGwyPFEsJm-hWxIZAFPVH73VC7FBq8aUoBZ_tfzNKRNrA0CpyQ&sa=X&ved=0ahUKEwiC_5Xpgr_cAhXQa8AKHb3pDKsQ2SsIDw
MIDI grooves can be found for £6.99
http://www.happydogmedia.com/products.aspx
Bearing all this in mind BFD3 is a lot more cost effective than SD3. AFAIK SD3 does not have third party expansion packs so you are on the upgrade bandwagon straight away.
I reckon that, for me at least, BFD3 is probably the better option. The main reason is that it will be easier to get a good reggae sound in a short space of time.
thefruitfarmer
Postby jamescrist » Sun Apr 04, 2021 8:44 pm
Glenn Bucci wrote:I started with BFD drums, then BFD 2, and then BFD 3. Recently I purchased Superior Drummer 3. I am still learning the program, but I have to say, I don't believe you can get better sounding drums than Superior Drummer 3. Part of the reason is the studio room chosen for the project, and the other reason is George Massenburg in the drum room and behind the mixing console.
I do a lot of jazz so it sounds like BFD3 would be a nice addition to my SD3! :-)
jamescrist
Postby uselessoldman » Wed Apr 14, 2021 7:26 pm
Superior Drummer is cool love it. The way you can import audio tracks it generates and creates drum patterns and you can split individual drums/hats cymbals etc and choose the one that suits your needs best and export to your track and still have editing features. Also like that you can import any sound or sample you like although I guess once you have exported the midi that easy to do in many other ways.
Have to admit I use Rock Foundry about 90% of the time without even looking at the others.
I have BF and to be honest I should delete it cant remember last time I opened it up same goes for AD. Not that either of them are bad but SD does what I need, all the time every time.
uselessoldman
Postby Tomás Mulcahy » Thu Apr 15, 2021 6:09 pm
Great reviews, very interesting to see the options. I'm very tempted by both products!
I'm using AIR Strike and I'm very happy with it. I like choosing the patterns on a keyboard. The number of patterns is limited but you can export the MIDI and edit it. The built in processing is not great, and rendering individual elements sometimes does not work as expected. But for the price I find it a great creative tool.
Tomás Mulcahy
Postby DeadRiff » Mon May 03, 2021 4:25 pm
I’m curious as to the workflow differences between SD3 and BFD3. I picked up BFD3 on a half off sale and have spent a lot of time with it, but I always go back to steven slate just because it’s quick despite the sound being subpar. Is the workflow for SD3 that much better?
Whichever one has more grooves is a nonissue for me as I write my drum parts myself. My biggest concern is being able to set up a good drum sound and be able to route out into separate channels within my DAW for processing if needed. One of my issues with BFD3 is that it auto-routes into so many channels and I’d prefer to set up the routing myself. Maybe I’m missing something, but I haven’t found a good way to do that despite watching a lot of youtube videos
That being said, another thing to consider is the wealth of tutorial videos available. I think with SD3 being much more popular, I constantly see videos about it while trying to find help with BFD3 can be a challenge
DeadRiff
Postby TheLegit » Mon May 03, 2021 5:52 pm
I used to have Superior Drummer 2 if the main thing is sound quality I would get SD3 and learn it's workflow but honestly I find SSD5 sounds so good I don't have an issue with it. They process the sounds to go nicely into your mix with a minimum of fuss. From what I remember assigning outs wasn't a big deal with SD2, just sent the various mics to their required channels (so I just sent all the snare ones to one snare channel and so on for simplicity) and all room mics to a seperate one to blend in or not as required.
TheLegit
Postby DeadRiff » Mon May 03, 2021 11:53 pm
TheLegit wrote:honestly I find SSD5 sounds so good I don't have an issue with it. They process the sounds to go nicely into your mix with a minimum of fuss.
They're definitely usable, but I can't get them to sound the way I want
TheLegit wrote:From what I remember assigning outs wasn't a big deal with SD2, just sent the various mics to their required channels (so I just sent all the snare ones to one snare channel and so on for simplicity) and all room mics to a seperate one to blend in or not as required.
That's good. That's one thing I can say is pretty simple with SSD5 is the routing out
DeadRiff
