Windows 10 for musicians SOS article
Re: Windows 10 for musicians SOS article
Postby CS70 » Fri Nov 20, 2015 8:01 pm
robinv wrote: <a href="/SOS/nov15/articles/windows10.htm" target="_blank">http://www.soundonsound.com/SOS/nov15/articles/windows10.htm</a>
I hope this article might be useful to some people here. I put a lot of time into getting the information right and speaking to the right people at Microsoft about it. Solid information can be hard to find so hopefully this is helpful to the conversation.
Cheers
Robin
Since nobody seems to have said it (but I'm sure everyone thinks it ): well done, very good article and it is actually convincing me to give W10 a try (on my new build, not on the laptop).
Great job.
Postby awjoe » Sat Nov 21, 2015 8:12 am
I don't think I know how to do it. What drivers do I need to make sure about? Interface, check. Video monitor will be taken care of automatically? What else? Will plugins that run on Win 7 run on Win 10? I hate this stuff cuz I don't understand it, but I think I'm going to do it.
awjoe
Fringe member of the Party Pooper People's Party
Postby ef37a » Sat Nov 21, 2015 10:05 am
I now have W10 on the "second best" music PC. Bit of a long winded process but no glitches.
A day or so ago I downloaded (on a W7 machine!) the W10 drivers for my NI KA6 and burned them to a DVD. Finding "Computer" in 10 was tricky but then I found the DVD drive and ran the drivers.
No sweat, just did the bizz and on connecting the AI it was found and worked straight off the bat. I then left it running all day on Radio 3 and it never missed a beat. After about 3 hours there was a "ClangWhooshe" sort of sound. I found "Banner Sounds" and turned them all off. No more clang.
I find ten bloody awful to be frank, almost nothing is the same or where it was in 7 and this PC will hardly ever be used except for curiosity. I shall certainly resist putting what someone descried as "Windows 7 with a tablet bolted on" on any of my other computers.
Postby Lostfollicles » Thu Dec 24, 2015 2:21 pm
Hi guys! I wanted to start a new thread but not sure of how to do that so apologies for tramping on anyone's feet!
There have been many discussions regarding Win 10 upgrades and possible future problems with Win 10 drivers supporting "Or not" hardware "Old and new" etc...etc... Indeed I had many problems with my Line 6 UX2 when I tried Win 7 on a new hard drive on my old Asus P4P800 as the UX2 would simply not work properly! The Asus P4 MB not good enough to run sataII drive it seemed or run Win 7 without seriously slowing down just about everything making it a total pain to use, so I have relegated that computer to stay on XP which runs flawlessly-ish!
One of the questions I want to ask you guys is: - Is there a non bloated version of Win 10 available??
I only want to use my computer as a DAW music making device, of course all software has to have an OS but I really don't want all the usual bloat and resource using windows crap that normally go's with an windows install!
Also recently I have been trying to investigate and source all the relevant information for building a new Audio work station that will run my favored DAW Sonar X3 and any USB audio interface that will work with windows!? I will of course be trying to use my UX2, however! As I said above it wasn't until I started to research all the new hardware that's available today that I am now well and truly perplexed! I have tried in vane to find any relevant information regarding the strengths or weaknesses of the now it seems favored for gaming Z99 or Z170 motherboards let alone the different Quad or Octa CPU's! I am now in a state of total stagnation computer build wise as I don't know which way to turn :frown: Help!!
Lostfollicles
Postby ef37a » Thu Dec 24, 2015 3:22 pm
Felicitations of the season L and welcome.
Now I am only the merest dabbler here but...That Line 6 has W7 (and W10) drivers listed so I suspect there is some other reason you could not get it to work with 7. Others here will surely have some ideas.
As well as this esteemed emporium I have infested at least two other recording forums for many years and cannot recall anyone having a problem with that AI and W7.That is not to say there has never BEEN a problem, just that it is not at all common AFAIK.
As for a new build? You will surely have advice from Olympus in the form of Pete (Scan) and Martin but it seems to this mere mortal that there are very few problems involved these days? I would look for a MOBO with plenty of USB 3 and especially USB 3.1 capability, i5 or i7 CPU, SSD main HDD and a 2TB or bigger spinner for backup. Much depends on what you need/want to do? Easy to go way overboard when all you have is a mic and a guitar!
But then I am just a V old valve jockey.
Postby Wonks » Thu Dec 24, 2015 5:17 pm
Win 10 does install a lot of stuff by default, though most of it is pretty easy to uninstall again. It's also easier than ever to decide what gets loaded on start-up, so you only have running what you really need to.
Postby Exalted Wombat » Thu Dec 24, 2015 5:47 pm
Wonks wrote:Win 10 does install a lot of stuff by default, though most of it is pretty easy to uninstall again. It's also easier than ever to decide what gets loaded on start-up, so you only have running what you really need to.
Out of interest, what have you uninstalled from your Windows 10 setup? Did it make any perceptable difference?
Exalted Wombat
You don't have to write songs. The world doesn't want you to write songs. It would probably prefer it if you didn't. So write songs if you want to. Otherwise, dont bore us with beefing about it. Go fishing instead.
Postby Wonks » Thu Dec 24, 2015 6:42 pm
Some of the apps like maps, news, finance etc. On a fast machine like mine, I don't really think it makes much difference. But the less there is, the less there is to start doing stuff like updating in the background.
Postby Exalted Wombat » Thu Dec 24, 2015 6:53 pm
Do the apps on the "dark side" auto-run then? I thought they were simple run-when-asked-for program.
I agree, the downside of Windows 10 is all this auto-update malarky. Though I'm not sure it's much different to what responsible Windows 7/8 users did anyway.
Exalted Wombat
Postby Atinshola » Thu Dec 24, 2015 10:07 pm
Quick question (ok, longwinded question):
I've heard that there is a 30-day limit for rolling back to Win7/8 - does this mean that if I install Win10 over my Win7 install and then do a clean Win10 install, and after say, 6 weeks, decide it's not for me and want to go back to Win7/8, I cannot do so, even by doing a clean install with my original (and legal) Win7/8 dvd?
Merry Christmas and a happy new year! :bouncy: :?
Atinshola
Postby Exalted Wombat » Thu Dec 24, 2015 11:42 pm
No, it means that a Windows.old folder is retained on your computer for 30 days, enabling an in-place roll-back. Obviously you'll also have a full system image of the computer, pre-update, as part of your routine backup strategy.
Exalted Wombat
How NOT to install Windows 10
Postby ConcertinaChap » Fri Jan 08, 2016 11:30 am
Just an aside. The Register has published an article on the official way to stop W10 being installed on your PC if you do not want it. The article is here.
ConcertinaChap
Postby alexis » Sat Jan 09, 2016 2:49 am
So ... if I wanted W10, after imaging is the best thing just to start clicking Yes on the big blue box that keeps popping up when I power on the computer?
Or should I somehow do a "fresh install" instead of going through their update process?
Thanks -
alexis
Cubase 9.0.1; i5-4570 3.2GHz,16GB RAM;W10 64bit on Samsung SSD840 Pro256GB;Seagte 1TB SATA600 Audio;UR28M;Motif8;UAD2Solo;Jamstix 3.3;BCF2K;TC Helicon VoiceOne;RevoicePro3.2
Postby robinv » Sat Jan 09, 2016 9:51 am
Accepted wisdom dictates that you should do a fresh install - which is a good and healthy thing to do from time to time anyway. However, ive now upgraded 3 different machines with no ill effects.
In order to do a fresh install you'll need to go through the upgrade procedure so that your system gets recognised for the free upgrade - so you can always try it and see before doing the fresh install.
robinv
Molten Music Technology - Computers for doing music on
Making Music on the Microsoft Surface
Postby The Elf » Sat Jan 09, 2016 9:53 am
I can't say it's the 'best', but the update is what I've done on all my PCs and it's been painless. All my software still in place and nothing to fix, short of the mousepad settings on my laptop.
PreviousNext
