Dodgy battery in mic causing issues
Postby Bill S » Tue Sep 18, 2018 10:02 pm
I have a Rode NT3 mic, and lately it has been producing a nasty, what I would call medium frequency buzz. In fact, I had no idea it was the mic, I thought it might be dodgy electrics in the studio, but I eventually worked out it was a cheap battery which I’d put into the mic only a month ago.
I took out the battery and switched on phantom power from my Focusrite audio interface.
Problem solved.
Maybe this helps someone else - I had no idea that a battery (I guess that was on its last legs) could cause such issues!
Bill S
Re: Dodgy battery in mic causing issues
Postby ConcertinaChap » Tue Sep 18, 2018 10:35 pm
Did you try putting a decent battery in and was it OK then? Just wondering as I've an NT4 which is similarly battery/phantom powered. I've not had any problems with it on battery although I've been using freshly charged rechargeables with it.
ConcertinaChap
Postby Bill S » Wed Sep 19, 2018 7:37 pm
No, I didn’t. I’ll have to splash out for a Duracell! Never had issues before. Perhaps not all batteries are created equal!
Bill S
Postby James Perrett » Wed Sep 19, 2018 10:26 pm
Bill S wrote:No, I didn’t. I’ll have to splash out for a Duracell! Never had issues before. Perhaps not all batteries are created equal!
I'd avoid Duracells as they have a habit of either leaking or going open circuit. There's a good battery comparison at http://www.batteryshowdown.com/
Postby ConcertinaChap » Thu Sep 20, 2018 9:05 am
That's a very interesting site and I'll spend time looking at that, thanks. However both the NT3 and NT4 take PP3-type batteries and I'm not sure the results for AA batteries will be directly applicable.
Cheers,
ConcertinaChap
Postby Sam Spoons » Thu Sep 20, 2018 10:54 am
I bought a load of Duracell Industrial AA batteries off Amazon which I'm convinced were fakes. They were very inconsistent, some lasted well but many of them died after a short time in use. No way to be sure though but I won't buy them that way again. A couple of years ago I bought ProCell AA s off Amazon and they were excellent with no dodgy ones (I even found a few unused last week which are fine).
Postby Bill S » Thu Sep 20, 2018 11:38 am
I’m still surprised that the battery seemed to cause buzzing as it started to run out of juice, rather than just going from (a) working fine, to (b) the mic suddenly creasing to work completely when the battery died.
I have also noticed more sibilance and indeed, that I seem to have developed a slight lisp in recent recordings. Could this also be due to a battery on its last legs do you think?
Bill S
Postby Ariosto » Thu Sep 20, 2018 12:32 pm
It could still be the mic. I've recently had two band new mics fail in some way (both with a lot of noise in fact, one noisy from day one, and the other after a few weeks [different makes]).
Are you using a pop filter or angling the mic slightly? This could help with sibilance.
Ariosto
Postby ConcertinaChap » Thu Sep 20, 2018 1:03 pm
Bill S wrote:Could this also be due to a battery on its last legs do you think?
No way of being sure until you try it with a known good battery, but I wouldn't be surprised.
As I say, my NT4 works fine with rechargeable PP3s and whenever I'm going to use it on battery I make sure the battery is fully charged first. This has proved reliable and has cut down significantly on battery wastage.
ConcertinaChap
Postby Bill S » Fri Sep 21, 2018 8:57 am
Very helpful, much appreciate your thoughts. Think I'll stick to phantom power from now on!
Bill S
Postby Hugh Robjohns » Fri Sep 21, 2018 11:38 am
Bill S wrote:I’m still surprised that the battery seemed to cause buzzing as it started to run out of juice, rather than just going from (a) working fine, to (b) the mic suddenly creasing to work completely when the battery died.
That's not the way of analogue electronics. The performance will degrade in myriad ways as the supply voltage decreases. Depending on the complexity of the circuitry and its design, some sections of the signal path might go unstable and start oscillating (which could explain your buzz). The bandwidth might change (which might explain your sibilance). The noise floor might change. Distortion will certainly change and might become asymmetric... All very complicated and largely unpredictable.
Entirely possible... but it's easy to find out: just stick a new battery in it and see if it all gets better! Moreover, the fact that all these problems went away when you switched to phantom power does indicate pretty conclusively that you had a low voltage issue on battery-power.
Postby Bill S » Sat Sep 22, 2018 11:10 am
Hugh
Thank you for taking the time to explain. Although the technicalities are beyond me, the answer seems to be to use phantom power all the time. I can’t see any reason whatsoever to use a battery in my studio. Unless you tell me otherwise!
Anyway, thanks again.
Bill
Bill S
Postby Martin Walker » Sat Sep 22, 2018 3:38 pm
Some esoteric stopboxes actually employ voltage starve to change their sound, anything from a change in distortion to schmitt-trigger-like gating.
I'm currently working on an electro-rhythm box that uses voltage starve with digital circuitry, for seemingly random chaotic sounds that can be disrupted so they play rhythmically.
Wonderful when used in the right circumstances! 8-)
Postby ConcertinaChap » Sat Sep 22, 2018 4:12 pm
Bill S wrote:I can’t see any reason whatsoever to use a battery in my studio. Unless you tell me otherwise!
Hugh may (and normally does) know better than me but I'd always use my NT4 on phantom power in the studio. It's out of the studio where battery power comes into its own, and I assume the same would be true for the NT3. Most commonly I'll plug it into my Olympus LS10 when I want to get a decent live stereo recording without going to the trouble of my full live setup. I can get best quality with the latter but quick and surprisingly good with the former can be ever so useful. Wouldn't be possible without the battery.
ConcertinaChap
Postby Hugh Robjohns » Sat Sep 22, 2018 5:03 pm
It's always going to be best to use phantom whenever possible -- and bet to take the battery out when it in use.
Phantom power often gives more headroom, lower noise and less distortion than the internal battery, and no risk of corrosive leaks or getting caught out with gradually worsening performance.
But of course, battery power has its uses now and again...
Postby Bill S » Sat Sep 22, 2018 8:51 pm
I really didn’t know that. So glad I started this post, I’ve really learnt something.
Must hang out here more often!
Bill S
Postby Hugh Robjohns » Sat Sep 22, 2018 9:46 pm
Depends on the sophistication of the mic's electronics, but usually the circuitry's operating voltage rail will be considerably higher when receiving phantom power, compared to a 9V battery. That translates directly to more headroom and potentially less noise and distortion too.
Postby Bill S » Tue Sep 25, 2018 3:18 pm
Unfortunately, after a few days trouble free motoring, the “medium frequency buzzing” I described in my original post has returned, this time with no battery in the mic and with it operating on phantom power.
It is clearly an intermittent issue. It only occurs when input echo is engaged. I don’t have another mic, or even access to one I can borrow to try to establish if it’s the mic. Ditto another audio interface. I have changed the mic cable, so it’s not that. It’s not related to any heavy duty household appliances being used. I don’t think it is an earth hum (frequency too high). It doesn’t occur when I plug in an electric guitar.
I live in Spain and it is tempting to blame dodgy household electrics, yet my gut says this isn’t the case, as it hasn’t been a problem before in the two years we’ve been here. I am beginning to think it might be the mic itself.
Any pointers as to how I can isolate the issue and discover the cause?
Bill S
Postby Wonks » Tue Sep 25, 2018 3:35 pm
I'd suggest it might be a grounding problem, where perhaps oxidation or poor contact between sections of the mic are stopping the whole case from being grounded and acting as a shield.
I'd use a multimeter to check that there's continuity between pin 1 and all the metal parts of the housing. I believe the finish should be conductive, though if not, there should be exposed metal around the screw threads, which would be better than nothing.
If you can't get a good reading from parts of the mic, then you could try taping a bare wire across all the metal surfaces and see if that cures the noise problem.
There are conductive greases containing carbon that you could carefully wipe around the screw threads of the separate sections to improve the overall conductivity if any break seems to be between screwed sections.
Otherwise it sound more likely to be a failing internal component. If you registered the mic, then it has a 10 year warranty instead of the normal 1 year.
Postby Bill S » Tue Sep 25, 2018 5:14 pm
I should throw in that the NT3 is 18 years old! Having said that, it has led a very sheltered life. I’m certainly not averse to buying a new mic, and I’ve had my money's worth with this one. But before I do, I’d obviously like to know if it’s the mic that’s at fault.
Bill S
Users browsing this forum: CS70, jodaki, zenguitar
