Any small near throw deep bass speaker exists?
Postby mikehende » Mon Nov 19, 2018 4:12 pm
Guys, I have had this predicament for a long time now where I need a bass which can sound deep "right around the speaker" and not travel. To add to this I am thinking something portable would be best so I will be able to use it both in my detached garage when I am hanging out in there and also in the yard so it will not bother those inside the house.
I have a Sony surround sound in the garage and had also tried a Bose system but the garage itself seems to act like a speaker and amplifies the bass so both surround sound subs sounds like an 18".
I may have to get 2 different speakers or setup for each situation so what's available nowadays guys which I can look into please?
mikehende
Re: Any small near throw deep bass speaker exists?
Postby Sam Spoons » Mon Nov 19, 2018 4:18 pm
This is to combat sound escaping to annoy the neighbours? If so I fear you are on a hiding to nothing. Bass speakers radiate more or less omnidirectional and bass is not much impeded by light weight construction material so a prefab garage would do little to keep the noise in (even if it was well sealed to prevent air leakage which allows all frequencies to escape).
Postby mikehende » Mon Nov 19, 2018 4:36 pm
Ouch!!
mikehende
Postby ef37a » Mon Nov 19, 2018 7:07 pm
You CAN build speaker systems that are directional at low frequencies.
This involves multiple power amps and phase shift networks.
Note, such systems produce the usual "microphone" patterns, cardiod, figure 8 so you can only have a null in one or two directions...Can't please all of......
Postby resistorman » Mon Nov 19, 2018 7:34 pm
Comfortable Bluetooth headphones? Bass loves to travel...
resistorman
future26.com
