True, and let's not forget the whole broadband industry with their 'up to XX Mb download" claims.
:madas:
Anyone using a Behringer X32 with synths?
• Page 5 of 5 • 1, 2, 3, 4, 5
blinddrew - Jedi Poster
Re: Anyone using a Behringer X32 with synths?
blinddrew wrote:True, and let's not forget the whole broadband industry with their 'up to XX Mb download" claims.
:madas:
They are buggers for it. Something that also throws a lot of people, is that an "Mb" is a Megabit, not Megabyte.
Luke W - Regular
Techie / Musician Of Sorts
The Elf wrote:Nope, that Tascam can't do both at the same time. Very few can.
Interesting, I was considering purchasing this over a X32 Compact. Might have to re-think that.
What is the point of the USB/SD/Input switch on each channel if you can't co-mingle the inputs w/ USB?
- hangnef
I'm not sure what you're picking up on here. My requirement is that the mixer needs to be capable of acting as an audio interface at the same time as recording its inputs internally. Most mixers can't do that. But likely all USB-equipped mixers can mix inputs with USB - which is not what I am referring to.hangnef wrote:The Elf wrote:Nope, that Tascam can't do both at the same time. Very few can.
The Elf - Jedi Poster
The Elf wrote:I'm not sure what you're picking up on here. My requirement is that the mixer needs to be capable of acting as an audio interface at the same time as recording its inputs internally. Most mixers can't do that. But likely all USB-equipped mixers can mix inputs with USB - which is not what I am referring to.hangnef wrote:The Elf wrote:Nope, that Tascam can't do both at the same time. Very few can.
Ah, so this is about recording rather than playback. Got it. Your Zoom L12 allowed for that, correct?
- hangnef
Yes, and did a very good job of it too. It has its compromises, as this thread will show, but it is a good device, especially for the money.hangnef wrote:Ah, so this is about recording rather than playback. Got it. Your Zoom L12 allowed for that, correct?The Elf wrote:I'm not sure what you're picking up on here. My requirement is that the mixer needs to be capable of acting as an audio interface at the same time as recording its inputs internally. Most mixers can't do that. But likely all USB-equipped mixers can mix inputs with USB - which is not what I am referring to.hangnef wrote:The Elf wrote:Nope, that Tascam can't do both at the same time. Very few can.
