Guitar multi fx with decent looping time
• Page 1 of 2 • 1, 2
5 minutes or more will do, more would be nice (and loads of memory slots) but the usual 40 sec or so is pretty useless.....
Sam Spoons - Jedi Poster
Re: Guitar multi fx with decent looping time
Is this for some prog rock epic where the intro takes 5 minutes before you can start to add things on top?
Wonks - Jedi Poster
No, much more prosaic
I just want a single fx unit that will do everything, rock trio, acoustic trio and solo/duo (both instrumental and vocal). The looper is mostly for the full AABA (or WHY) rhythm guitar to solo over (so 90 secs minimum before overdubs). The TC Helicon VoiceLive 3 Extreme does it but is, primarily, a vocal fx unit (though the guitar fx are very good). So does the Helix but at a price..... TBH I don't need loads of effects, my electric pedalboard has a Cry Baby wah, clean boost, TC Dual Vintage Distortion (more or less two Tube Screamers in a box) a delay, a reverb, a tuner and a looper, the acoustic one needs, boost, delay, tuner and looper. A decent eq for acoustic would be nice too, though I suspect all the more sophisticated boards will have one.
Mind you I do dream of being in a Prog Rock band (but probably don't have the patience and ability) so you never know......
The Helix does do it all, a number of pro's use them for everything (including acoustic) but as you note, it does have a pro price tag...
Does it have to be a single unit? What about a small board with a wah, MFX like say the Line 6 M series or the cut down Helix and then a looper?
Given the hands on nature of the looper I'd suggest having this as a dedicated box might make your life easier. And you can then easily swap loops around for gigs/rigs etc.
What puts you off using the electric board for acoustic, noting you use pretty much the same kit for both?
Hewesy
Hewesy
- Hewesy
- Frequent Poster
Sam Spoons wrote: The looper is mostly for the full ABBA rhythm guitar to solo over
OK, Björn.
Wonks - Jedi Poster
Helix will give you 60 seconds stereo, 120 seconds mono. I can't think of a hardware looper that would take you further (TBH I can't imagine wanting more than 120 seconds of loop!)
With the Helix you could leave all your other stuff back home. It isn't cheap, but it really is very good indeed. Once you discover the multiple I/O capabilities (four simultaneous stereo inputs, each with separate effects chains, for example), mic input, USB/MIDI, multi-channel audio interface and other goodies, you really do begin to realise that it's a whole lot more than a stomp box replacement.
There are cheaper Helix versions (and I believe they are all patch-compatible), but you have to accept compromises as the price drops.
The Elf - Jedi Poster
Hewesy wrote:The Helix does do it all, a number of pro's use them for everything (including acoustic) but as you note, it does have a pro price tag...
I do have a second board for acoustic which has just boost, tuner, delay and Ditto X2 Looper
See above, but I have just sold the TC Ditto mini (off the electric board) and Ditto X2 and bought two DittoJam X2s as they claim to be able to stay in sync with a live drummer or rhythm player. Jury's out as I've only just got them but will report back.
Hewesy
Size plain and simple, it's quite big and heavy. Losing the wah, distortion and reverb (the AER acoustic amp has one built in, the 18 watt combo doesn't) makes a lot of difference and the acoustic board is less than half the size/weight. It also runs off a PedalTrain Volto so no mains needed which is great for open mic sessions (mains power requirement may be a reasons not to go for an all in one solution).
The Helix might seem expensive, but for what it does and what it costs in real terms it's a complete bargain.
My first multi-effects unit was a Roland GP8 which I bought second hand in the late 80s, and did only a fraction of what the Helix is capable of, but IIRC only a couple of years earlier the new price for this and foot controller to go with it was close to £1k when that was worth a lot more in real terms compared with £1k today.
BigRedX - Frequent Poster
RockinRollin' VampireMan
The Elf wrote:Helix will give you 60 seconds stereo, 120 seconds mono. I can't think of a hardware looper that would take you further (TBH I can't imagine wanting more than 120 seconds of loop!)
I might consider the Helix, one of my guitar heroes (Remi Harris) uses one and have looked at the TC VoiceLive 3 Extreme as I mentioned above.
The VL3E has, I think, 5 mins looping as do the Ditto series but no loop memories, I also have a Boss RC3 as a 'gig bag looper' and a Boss RC30 both of which have 3 hours stereo loop memory and 99 memory slots. So I'm well endowed with loop pedals
BigRedX wrote:The Helix might seem expensive, but for what it does and what it costs in real terms it's a complete bargain.
I have had a Boss GT3 for many years, which replaced my GX700 rack and FC200 (I still have the FC200)
Elf? can the Helix do basic vocal harmonies? The thing that stops me buying a VoiceLive 3E (and I've had several VL products, Harmony G, VL1. VL2 and currently VL Play GTX) is that it compromises the guitar fx (obviously) in favour of the vocal fx and what I want is the other way around, good guitar fx, a decent looper (and yes 2 mins would probably be enough for most things but see my earlier post) and basic vocal harmonies in one box.
I will download and read the Helix manual later I promise
Writing this reminds me I need to perform another cull of fx/stomp boxes
Hmmm... It has a harmoniser in there, but I doubt that it would be suitable for vocals.Sam Spoons wrote:Elf? can the Helix do basic vocal harmonies?
This guy on YouTube details adding a TC Helicon in a loop from the Helix: https://youtu.be/MZC5QZocKLQ
If you're at the SOSMeet tomorrow I can bring mine along?
One day maybe but it's a bit of a trek and not tomorrow. Thanks for the offer though. TBH the guitar fx on the Play GTX are pretty decent and probably do enough but the 30sec loop time is not enough to be useful for my needs so I'm back up to two boxes
. Probably a TC Harmony Singer and a guitar multi fx would be the way to go but I already have all of those facilities and it's still 2 or more boxes. I've just rebuilt the acoustic board with a Ditto Jam, mini delay and the Tone Dexter (which does boost and has a tuner) so I'll try that for a while while reading up on various guitar fx units.
Maybe I should document my current fx collection, it seems to be pretty extensive......
Fair enough Sam, just curious but yes that makes perfect sense.
What about splitting the boards into 2 small Pedaltrain units? Would also make 2 lighter boards to move rather than one unwieldy beast... wouldn't take much to have a loom made to connect both up as needed.
Great taste with Remi Harris, what a talent...
Hewesy
Hewesy
- Hewesy
- Frequent Poster
It's not too unweildy only a PT Mini with 7 stompers on it (the gap is where the TC Ditto was before I gave it to my mate the bass player, it will be replaced with a DittoJam X2 shortly, the other couple of boxes are an Airturn and associated footswitch). I'm happy using it for it's intended purpose, it's the acoustic board I'm trying to resolve really, currently it has a TC DittoJam X2, a mini delay and the Tone Dexter. I think it may be that I'm suffering from pre-Christmas GAS rather than any need to change.....
Remi Harris is one of my two favourite Gypsy Jazz guitarists (neither of them Gypsies as it happens) Joscho Stephan is the other. Both are not to shabby playing other styles either
Joscho is here (this filmed ten years ago now) :-
https://www.youtube.com/watch?v=99R7VW9QqyY
Sam Spoons wrote:5 minutes or more will do, more would be nice (and loads of memory slots) but the usual 40 sec or so is pretty useless.....
The trio band creator allows 230 secs if I recall.
CS70 - Frequent Poster (Level2)
Yeah considered one but doesn't really do the other stuff I need. I find it hard to understand why otherwise brilliant devices like the Helix include a looper but then only give 60 secs of stereo loop memory (and no loop storage) when a £60 looper like the TC Ditto can have 5 mins of stereo loop memory and a £100 one (the RC-3) has 180 mins of stereo loop memory and 99 memory slots. Compared to the cost of a Helix the cost of extra memory can't be an issue. I still wonder if a VoiceLive 3X at half the price of a Helix would do what I need but it seems daft to pay for loads of vocal fx, most of which I won't use........
Maybe at a future update the Helix will include some vocal fx and more loop memory (though that's probably a hardware limitation).
Sam Spoons wrote:Mind you I do dream of being in a Prog Rock band (but probably don't have the patience and ability) so you never know......
The Dark Side Of The Spoons.
Wonks - Jedi Poster
Users browsing this forum: CS70
