Acoustic stomp box
Re: Acoustic stomp box
Postby Sam Spoons » Fri Dec 14, 2018 12:37 am
You've set me thinking again about stomp boxes and I re-jigged my drummer/mate's home made stomper with a precision pickup an iron plate.... It sounded shit.....so I'v gone back to piezo for that one. I suspect the problem is that the top is too thick. I'll try a few things and post back here if I find anything useful. :thumbup:
Postby ben howes » Fri Dec 14, 2018 1:22 am
The spd 1 is a neat single box electronic solution. However a second hand Roland tm2 or cheap alesis box or old drum machine with a trigger input would do the same job. Just add a 20 pence piezoelectric element on some ply with a bit of mouse mat on top. Tweak the trigger settings a bit. Have fun.
ben howes
Postby ef37a » Fri Dec 14, 2018 10:02 am
Fascinating!
Just a point about piezo transducers? To get a really deep sound out of them they need to go into a very high impedance. For acoustic guitar, not less than 5meg is suggested and 10 is better. For this thumper I would go for 22meg or even more. The bog S TL072 can cope with that quite easily but there are better jfet op amps, in fact it might be wise to avoid the '72 as they can "latchup" if overloaded.
Postby Hewesy » Fri Dec 14, 2018 1:18 pm
If not too late the Porch Board is worth a nose, though I suspect they have gone up in cost...
On a Bellowhead note Jon Boden now solo tours with a board but it is large enough for him to stand on an use both feet. He uses a stick on mic and/or piezo depending on the gig. Phillip Henry is another great floorboard player to check out. Both have/had YouTube vids showing their rigs off.
Seth Lakeman uses a smaller homemade unit, and alternates between heel and toe for thump or click type tones. I think that used a mic inside and he could mute it onstage.
Seasick Steve had a flight case with a guitar pickup inside, or go proper folk band with an old sturdy suitcase and a bass drum kick pedal.
DIY could be your friend here, and enable you to dual purpose it as say a case or box for other gear for transport.
Hewesy
Hewesy
Postby Sam Spoons » Fri Dec 14, 2018 2:02 pm
Yup, definitely fancy a large board like the Bellowhead one (600 x 600 mm) so I can stand on it and stamp both feet. T'would make me look taller too which would be a hidden bonus :smirk:
Postby Hewesy » Fri Dec 14, 2018 4:07 pm
Funnily enough I had the same though when I saw Jon Boden, then we met him afterwards to sign a CD - Jeebus he's tall!
Check this out from the man himself, from last years tour IIRC (which is a great album if you haven't picked it up).
https://www.youtube.com/watch?v=phDw345SCcM
Such a fan of his Bb tuning too, how he makes so much noise as one man for the Bellowhead "biggies" - true Wayne's World moment.
Hewesy
Hewesy
Postby Sam Spoons » Fri Dec 14, 2018 4:25 pm
Brilliant, loved Bellowhead, love Jon Bowden, (and John Bowers). I was lucky enough to do PA for Faustus a few years ago, Benji Kirkpatrick, Paul Sartin (both from Bellowhead) and Saul Rose (Martin Carthy's Squeezebox player) also brilliant, and nice guys to work with.
Postby Hewesy » Fri Dec 14, 2018 6:12 pm
Big Faustus fan here too mate, i saw both of their sets at Towersey this year and we saw them 2 weeks back on the latest tour.
Not surprised they are lovely, it cone across when you speak to them after the gig. Though I did rather shout at Benji after he opened for the Levellers last year - but only because they'd just given me tinnitus...
Hewesy
Hewesy
