Boss RC-505 - Saving Sytem Settings
Postby The Elf » Wed Jan 23, 2019 11:13 am
It seems every time I power up my Boss RC-505 the System settings are back to default. It's getting tedious having to reset all my custom settings in there. Does anyone know how I save them?
Re: Boss RC-505 - Saving Sytem Settings
Postby Hugh Robjohns » Wed Jan 23, 2019 4:23 pm
From page 5 of the manual:
If you select a different phrase memory or turn off the power after recording or editing the settings, the recorded content or edited settings will be lost.
If you want to keep the data, you must save it.
1. Press the [WRITE] button.
2. Use the [MEMORY/VALUE] knob to select the save-destination.
3. Press the [WRITE] button to save.
Does that help?
https://static.roland.com/assets/media/pdf/RC-505_e02_W.pdf
Postby The Elf » Wed Jan 23, 2019 4:47 pm
Thanks for helping, Hugh. It's always appreciated.
That manual reference relates to saving one of the many 'Phrase Memories' - not the machine-wide 'System' settings. I can't see anything in the manual that relates to saving these parameters, so one might assume it would be automatic. The system settings contain such things as auto power off, line output settings, MIDI channel and the like. After a power-cycle they are resetting to default.
I started wondering if the internal batteries were duff, but it's storing everything else between power cycles - just not the settings that affect the machine as a whole! Odd...
Postby CS70 » Wed Jan 23, 2019 6:20 pm
Hmm.. according to https://www.boss.info/us/support/knowledge_base/201975189/ the same procedure should apply to system setting, by selecting the relative slot?
Postby The Elf » Wed Jan 23, 2019 8:34 pm
But System settings are global - they don't have a 'slot'.
The link you've given here is to Factory Reset, BTW!
Postby CS70 » Wed Jan 23, 2019 8:58 pm
Hehe yes I'm aware, but it was point 4 that got my attention:
Turn the MEMORY/VALUE knob to select the desired range of parameters you want to reset (SYSTEM + MEMORY, SYSTEM, MEMORY).
It sounded a bit like the same language as page 5 in the manual where it talks about how to save (generically).
But it obviously wasn't - my bad.
Haven't got my hands one one unit, there's one at the studio but I'm not scheduled there til next week.. hopefully you'll have found out by then!
Postby The Elf » Wed Jan 30, 2019 12:37 pm
Weirdly the thing now seems to be storing System settings between power-ups without any intervention on my part.. Hmmm...
Postby CS70 » Wed Jan 30, 2019 2:16 pm
Yeah I was going to write, just tried last night the RC at the studio and it was doing just that - no need of explicit save.
It may be that it uses some CMOS memory like PCs used to do, and thus a battery to keep the settings... maybe it had somehow dislodged in yours? Or if it is a newer model it should have an SD card, and maybe that got out of whack somehow..
Postby Sam Spoons » Wed Jan 30, 2019 2:39 pm
Boss don't seem to use removable memory. Now they have 3 hours onboard (RC-3, 30, 300 & 505) that's not much of an issue but the RC-20 with only 5 ½ mins and RC-20XL with 16 mins pretty much rendered most of the 11 memory slots redundant. OTOH my TC Ditto has 5 mins which is plenty for my live looping needs.
Postby CS70 » Wed Jan 30, 2019 2:42 pm
I have a vague recollection reading that for the newer models, there should be an SD card, not removable, but internal and attached to the motherboard. But haven't really opened one so could well be mistaken.
Postby Sam Spoons » Wed Jan 30, 2019 2:52 pm
Not come across that but I guess it's possible, It would make upgrading the onboard memory a breeze though (on the basis it would be pointless to solder it to the board. I suspect them memory is soldered on SMT chips though.
Postby The Elf » Wed Jan 30, 2019 4:12 pm
I'd been told explicitly that there's no SD card option on the RC-505, but hidden somewhere inside? An intriguing thought!
But for me it's fine as it is. I only use it for live improv and it's more than up to that task.
Postby CS70 » Wed Jan 30, 2019 4:16 pm
The Elf wrote:I'd been told explicitly that there's no SD card option on the RC-505, but hidden somewhere inside? An intriguing thought!
If you were to open I think it you would see an SD card (which I guess it uses to store everything) - either soldered or hopefully inserted in an interface container as Sam says. Dont think it's particularly serviceable though, I've seen pictures of the motherboard with a glob of glue over it.. but you never know :D
Though I realized that wouldn't explain the behavior you're experiencing, if the problem with the save setting was the card, it wouldn't be able to save much else.. unless the file got corrupted somehow and it has an auto-recovery that kicks in. A mistery :)
Postby Sam Spoons » Wed Jan 30, 2019 5:47 pm
Unless somebody has faked the pic it seems like the 505 does use MicroSD memory. I suppose it's a cheap way of being able to upgrade future versions at the manufacturing stage maybe with new firmware and a bigger memory card?
https://postimg.cc/k6rbh1vp
Must take the RC-300 I've just bought to bits and see if it has one, (though I guess I should wait until the warrantee runs out). So if anybody wants a mint, boxed RC-30 a sensible offer by PM would secure it before I stick it on ebay.
Postby Wonks » Wed Jan 30, 2019 5:50 pm
Pic...
Next
