Audio/MIDI USB interfaces for the iPad/iPhone etc
• Page 2 of 3 • 1, 2, 3
Re: Audio/MIDI USB interfaces for the iPad/iPhone etc
Hi. I have an Akai LPK25 that I am trying to run through an iPad Air 1 using a standard, generic CCK. It starts working but after a few minutes (it varies) I get an error message stating that the device is not supported. Do you think that this is a power issue? If so, would a powered USB hub or the USB3 CCK discussed above solve this?
Thanks for your help. I’m going away for a few days and would love to be able to solve this on the cheap.
Rubber5oul - Regular
I've seen this a few times and it seems related to the cables. When I've gone cheap on cables I've had this message and the only solution was to buy some good branded cables at which point that error message went away.
The Elf - Jedi Poster
Hi Rubber5oul!
It might just be relevant to have a read of this:
www.pocketables.com/2013/02/how-to-get- ... apter.html
Hope it relates to your problem!
Martin Walker - Moderator
Could be the cable, it was dirt cheap lol. Interesting read about adding a non powered hub into the chain. I'll try that when I get home and report back. Thanks.
OK so I tried putting the unpowered hub in the chain. Sadly the problem persists. Looks like it might be the CCK but I'm not keen spending £39 on the off-chance. I shall ask amongst friends and see if anyone has an Apple one I could test it with.
Will report back again...
BillB wrote:Time to add to this...
Alesis Photon X25 (DC powered) > CCK > iPad Air
Is there any chance you could share the original Alesis drivers and the latest fixed ones if possible, so i can install them on my old Win XP laptop? I have seen this keyboard for sale at a local studio clearance, and it looks ideal for what I need and is in mint condition. There seems to be no trace of them on the Alesis website.
- Neo-Classical Guitar Man
- Regular
Footloose and fancy free...gizz a job!
The X25 is "class-compliant" which is why it works with the iPad. It doesn't need any drivers for Windows 7/10, not sure about XP but the chances are that you can plug it in and it will work.
Actually, I just rummaged through my files and found soemthing called:
AlesisPhotonX25-usbfix_v1_04.zip - which mentions WinXP in the readme file.
Don't remember using this, so you would be on your own. I will PM you with a link.
Bill
Bill
- BillB
- Frequent Poster
Also, just Googled for Alesis Photon X25 usbfix v1_04 and a few downlaod options came up.
- BillB
- Frequent Poster
Can anyone give me an idiot's guide to recording digital audio from an iPad into Protools? I have a number of synths, like Animoog and want to play them in real times as I am recording on Protools.
I have tried to follow various guides (one is from Sweetwater iOS update and discusses Inter App Audio and currently have set up and Aggregate I/O. I have connected the iPad via lightning connector and have enabled it in Audio-Midi setup/audio devices. The ipad comes up as having an input but the output is greyed out. Next to iPad it says 2 ins/0 outs.
I have opened Pro Tools and selected the playback engine as aggregate . I have then gone to I/O and under inputs, it says built in microphone. With output, it says Built in output. I was expecting the input to have a built in input but it doesn't - only built in microphone.
I have tried deleting the I/Os and selecting default but there is no sign of the iPad. Help!!
- Guest
Just adding the Focusrite iTrack Dock, which works fine via the Lightning connector.
Well, "fine" ... but with caveats. I use an iPad Air, but I think some thinner iPads need an extra shim so that the port/connector is correctly aligned. Another niggle: even some class-compliant USB MIDI controllers don't work (when they should, including some Korgs), and there are no 5-pin MIDI ports to use as an alternative. I'm currently using a Keystep.
And another, more annoying one (a facepalm-level design flaw): an electric guitar plugged into the Hi-Z input has excessive noise when recording. Because there's no grounding via the iTrack! So you get all of the 50Hz EMF hum that your guitar pickups can suck out of the air.
Workaround: to get the lowest noise floor, you can ground the unit another way. At home I did this by plugging the unused input into a nearby Integra 7's headphone socket (Integra is a proper device, with a permanently grounded chassis and jacks even when switched off). The noise floor was then normal. Same should be true if you plugged the iTracks outputs into some grounded active monitors.
Overall - working for now, but not ideal.
- Escapegoat
- Regular
Hi Escapegoat!
Well done in finding an alternative earthing point that solved your noise problem :clap:
If only all grounding issues were so simply and elegantly solved!
Hi all,
I'm running quantiloop pro on my ipad 3rd generation (30pin connector). I want to connect my usb alesis io2 souncard to the ipad so that I can use the inputs on the soudcard to play and record loops on guitar/vox. I went and bough a camera connection kit (30pin to usb adapter) and a usb 3.0 power hub. When connecting the hub into the ipad I get a message 'USB hub 2.0: the connected device requires too much power'. This is happening before I connect the soundcard into the usb hub which leads me to think the usb hub is not working might not be compatible with the camera connection kit?
The other issue that comes to mind is newer versions of the ipad run usb-c to apple lighting/usb 3 connector which means the ipad gets power from connection the charger into the usb 3 socket. Could this be the issue as my ipad is not getting power from anywhere?
Many thanks
Many thanks
- Piloadami
- New here
Hi Piloadami
It sounds like the hub is not receiving power independently (presumably you have an AC-DC adaptor for it) and is therefore trying to draw power from the iPad. Can you check this? For example, does the hub power/charge other devices (keyboard, phone etc?). iPads are fussy (by design) as to which peripherals they will work with. Cheap (non-apple) options can fail, but then again, there are usually no apple-produced options for older devices like your 30-pin iPad.
Also, I recall that the Alesis "iO2 express" will not work with the iPad, irrespective of power arrangements. I hope you have the older iO2, which is at least theoretically compatible if you can get the power issue resolved.
- BillB
- Frequent Poster
Piloadami wrote:Hi all,
One thing: Apple lies about USB power consumption. On some models on later versions of iOS, a USB device which won't work (popping up the message you saw). But it WILL work when connected via an UNPOWERED hub! Sounds completely batty but it's true. See here for one example: https://www.youtube.com/watch?v=J-I-nnocYtU
Of course, this might not be the only problem you have if the Alesis is not iOS compatible.
(Like you I have a 3rd gen iPad and Apple's CCK and after an iOS update the USB thumb drive I had suddenly "consumes too much power". Complete Apple BS. I got a £2 unpowered USB hub as shown in that video and the thumb drive now works fine. I'm pretty sure that Apple's arrogance makes third party suppliers think twice about making devices for iOS.)
- Escapegoat
- Regular
BillB wrote:The X25 is "class-compliant" which is why it works with the iPad. It doesn't need any drivers for Windows 7/10, not sure about XP but the chances are that you can plug it in and it will work.
Bill
Hi, Bill.
I'm looking forward for the PhotonX25USBfix_v1_04.zip file. Do you have it? If so, will you send a valid link for downloading it? I'm driving crazy looking for it in internet!
Thanks a lot.
- smntk
Hi smntk , welcome to the SOS Forum. I’ll PM a link tomorrow when I am in front of my PC.
- BillB
- Frequent Poster
Escapegoat, I have had that warning about a memory stick, "Insufficient power for device" on a desktop PC even though the same port would happily run a bus powered AI!
I don't think it is just (or at all?) a power issue, maybe more a "handshake" problem?
- ef37a
- Jedi Poster
Thanks a lot, BillB! I go running to test it! :thumbup: :clap:
- smntk
Working on Windows 10 !!!!!
Thanks a lot, BillB!!!!
But it was a headache to install windows XP with a virtual machine, and to have the files in the XP system. It couldn't read an USB device, it couldn't share files with host machine (running virtual machine under windows vista), it could't connect to internet neither via WiFi nor via ethernet cable. Finally, I decide to try with a really really legacy device: a CD :lol:
Surprisingly,I found a blank CD in a drawer, I burned it and... it worked!!!!!!!!!
Now, my alesis Photon X25 works perfectly in Ableton 10 Live! Even the axyz 3D controller dome!!!!!!!! :clap:
Thanks again, BillB for bringing to life my old Photon X25!!!! :thumbup:
- smntk
Excellent new, smntk - glad you got there in the end! The X25 is quite a neat little keyboard.
- BillB
- Frequent Poster
