HOW TO CONNECT SUBS WITH DXR15
Postby gsc1ugs » Sun Jun 09, 2019 11:56 am
I'm goin to get some subs probably dsx12 so my question please is this, do i use thru connection or link out at the bottom of the dxr15 cab? would i also leave the settings to FOH and HPF to off
Thanks in advance
gsc1ugs
Re: HOW TO CONNECT SUBS WITH DXR15
Postby Dave B » Sun Jun 09, 2019 2:26 pm
If you are using DXS15 subs then, yes, use the 'thru' for the tops. Turn the HPF to 'on' so that you aren't wasting energy on frequencies that the subs handle. I would probably set the FOH to 'on' as well as there is a slight top end lift. But that will be a personal preference thing so try it and see which you prefer.
Dave B
Postby Dan LB » Sun Jun 09, 2019 5:05 pm
12” Subs with 15” tops?
I’d suggest the other way around. Replace your DXR15s with 10s or 12s and get a single DXS15 sub for the time being. I had that exact setup (DXR12s over a single DXS15 sub) a couple of years ago and I would say that nothing new in that price range could beat it. It was quite a powerful, and great sounding compact rig.
Dan LB
Postby Sam Spoons » Sun Jun 09, 2019 6:06 pm
Yup, putting a 12" sub (or two) under a 15" speaker is far from optimum, you may get a little more headroom from the tops but probably no more bass than without. I use 2 QSC K12s over a single EV15" sub and it works very well. Two DXS12's a DXS18 do not make.......
Postby gsc1ugs » Mon Jun 10, 2019 10:32 am
:shock: i have sell my dxr15’s? Can a 18” sub work?i love these 15’s
gsc1ugs
Postby Sam Spoons » Mon Jun 10, 2019 11:02 am
An 18" sub will give you more extension and free up a little extra headroom in the tops. If you like em then keep em, they are good speakers
Postby gsc1ugs » Mon Jun 10, 2019 2:43 pm
Anyone know a good 18 sub? size is an issue so smaller better
gsc1ugs
Postby Sam Spoons » Mon Jun 10, 2019 3:15 pm
All the name manufacturers make decent 18" subs, compare cost, max SPL and size, they won't vary much on size. A quick glance suggests the JBL EON 618S might be a contender https://www.thomann.de/gb/jbl_eon_618_s.htm but go and see if there's anything on a deal at your local shop.
Postby gsc1ugs » Mon Jun 10, 2019 4:07 pm
So consensus is the dxs12 sub wont improve anything?
gsc1ugs
Postby Sam Spoons » Mon Jun 10, 2019 5:07 pm
Yup.
Postby MarkPAman » Mon Jun 10, 2019 6:42 pm
If you want a consensus, then:
Yup.
MarkPAman
Postby Music Wolf » Mon Jun 10, 2019 8:40 pm
I have DXR12s. When I’ve tried pairing them up with small (12” ) subs, or even bigger subs that weren’t up to it power wise, I’ve thought - why have we bothered?!!
The matching subs for the DXR15s are the DXS18s. There are other subs that would also do the job but they will be as big, as heavy and of a similar price to the Yamahas. Have a look at the specs and see if this is something that you could store, transport and set up.
Music Wolf
Postby gsc1ugs » Tue Jun 11, 2019 7:32 am
Thxs for that will have a look. I hoped technology had got better but i suppose thats just top end, i believe to push air size does matter
gsc1ugs
Postby Sam Spoons » Tue Jun 11, 2019 9:48 am
Correct, as Scotty would say "ye canna beat the laws o physics Cap'n"
Postby gsc1ugs » Tue Jun 11, 2019 11:31 am
Why is this cab over a grand??? Dxs18
gsc1ugs
Postby Sam Spoons » Tue Jun 11, 2019 12:12 pm
'Cos it's good. It's considerably louder than the cheaper ones, probably sounds better too. It's also very heavy though.
FWIW this one is €3500 and is passive/un-powered https://www.jsfrance.com/en/caissons-de-basses-actifs-passifs/11603-l-acoustics-renfort-de-grave-passif-sb18-version-2-neuf-2100000126361.html
Postby gsc1ugs » Tue Jun 11, 2019 1:31 pm
Is a sub not just a thump downstairs? i cant understand why something is this expensive even that passive link you sent :headbang: :o
gsc1ugs
Postby Sam Spoons » Tue Jun 11, 2019 1:53 pm
Being pragmatic, in most places I play the sub is just producing some extra thump but, even then some sound much more musical than others. Cheap subs usually sound very 'one note'.
Postby gsc1ugs » Tue Jun 11, 2019 2:07 pm
gsc1ugs
Postby gsc1ugs » Tue Jun 11, 2019 3:47 pm
What is this?
Equipped with: 1x 18" Ferrit Woofer
gsc1ugs
Next
Users browsing this forum: Black Sheep
