Peter H wrote:Has it worked satisfactorily in the past? Have you updated the firmware or app since?
I've only had it a short time. Problem from first (and only) outing. As above, have tried factory reset as suggested.I suspect its unique feature set was its downfall because it probably only met the needs of a very small number of users, as you are one of the few that is obviously good for you (as long as it works of course).
You may be right, but even in my local experience, this could be brilliant for small (jazz etc) combos - nearest equivalent is Club XS6, or much bigger digital mixer - prodx4 fits in my small bag.
Yes, I very nearly bought one (partly for the cute factor) but, in the end, I bought a Berry X-Air 12 but, as you say, it's a much larger box.
