Hows my mix?
Hows my mix?
Postby Ractor » Fri Aug 23, 2019 5:35 am
Hows my mix? Any advice would be greatly appreciated. I'm concerned about the vocal level mostly. https://youtu.be/wgfnD9MyU94
Ractor
Re: Hows my mix?
Postby Martin Walker » Fri Aug 23, 2019 9:50 am
Hi Ractor, and welcome to the SOS Forums! 8-)
I've just approved this your first post, so you can now get some feedback on this track of yours.
I've just had a quick listen at low volume and really liked what I heard. Lovely attitude and good instrumental balance and separation. I'll listen later on a bit louder and see whether I notice anything more, but on this first listen the vocal level sounded fine to me.
However, it would be most useful to know more about you and your music - tell us more!
Re: Hows my mix?
Postby Ractor » Fri Aug 23, 2019 3:59 pm
Thank you Martin. I appreciate this greatly.
I did a couple demos 20 years ago. But that was before i could learn so much from YouTube. And the last 6 months if been learning everything i can about recording, mixing and mastering. I have not mastered it yet. I spent about the last 9 days , 12 hours a day mixing it. My next song will probably take only a few hours now that i have a better idea what i need to do.
I'm in London Ontario. I did everything. I made the drums with samples with Addictive drums. The guitar is a low end Les Paul recorded through Amplitube, a Mesa Dual and a 5150. Both with a couple different mics on each cabinet. Jazz bass, played through Amplitube Ampeg. Bass DI, very slight distortion on just the hi frequencies. And a SM7B. I use Abbey Road Studio 3 virtual studio. Since i dont have sound treatment in my room or a sub. I referenced it with a few songs on as many different speakers i could find.
And for all the mixing. Everything was in the box. Using Studio One. I listened to what other pros were using for analog gear on each instrument and mix bus. And i researched for those specific emulations.
Let me know if you want to more. Again, Thank you !
Ractor
Re: Hows my mix?
Postby mammy » Fri Aug 23, 2019 5:44 pm
electro guitars are a bit dry . you can add them reverb and delay .when ı listen ı wanna hear bigger and fuller guitars .finally vocal sound is a bit low .bass guitar is a bit thin.you should thick it. if yo do these things your mix will be perfect :thumbup:
mammy
Re: Hows my mix?
Postby Ractor » Fri Aug 23, 2019 8:04 pm
Thanks Mammy. Will see what i can do. :thumbup: . I have reverb on the guitars panned to the opposite side. Ill just bring them up. I should put delay though? i assume a real short one
Ractor
Re: Hows my mix?
Postby blinddrew » Fri Aug 23, 2019 8:18 pm
Not really my genre so feel free to discard, but I'd agree with Mammy that the guitars could do with a bit more verb. It may open up a bit of a can of worms though because if you do that you might find you need to do the same with the drums; the snare in particular is very forward and might feel too much so.
Very accomplished composition and playing / programming throughout, plenty of structural variety to keep it interesting.
Going back to your first question though, I'd be tempted to nudge up the vocal during the louder sections. But I'm a singer so I would say that.. ;)
Re: Hows my mix?
Postby Ractor » Fri Aug 23, 2019 9:42 pm
Thanks BlindDrew. I had all the reverb set up. It was just so low that it was basically off. Bring it in on the guitars and drums really help glue the mix together. Specially the guitars. Ill be uploading an updated version soon. You guys are the best. Theres no way i would have figured that out on my own. But i can hear everything you guys are saying now.
Ractor
Re: Hows my mix?
Postby blinddrew » Fri Aug 23, 2019 9:47 pm
If, like me, you're fairly new to mixing, I think one of the most powerful tools you can use on any mix is a second opinion. :)
Re: Hows my mix?
Postby Martin Walker » Sat Aug 24, 2019 11:41 am
Hi again Ractor!
Glad you've had plenty more feedback already. I've just listened at a more realistic playback level and can now hear the things others have mentioned more easily. It's ironic that your vocals seem clearer at low playback levels :headbang:
The first vocals from 0:13 onwards could do with perhaps 1 or 2dB increase in level, as could the harmony vocal between 0:19 and 0:22 (I didn't even notice this harmony previously, but it would strengthen the mix to pull it up with the main vocal).
However, I personally think the 1:05 to 1:25 vocals are already at the perfect level.
At 1:33 to 1:50 they could come up a little again, as the tracks getting more aggressive at this point. However, once again at 1:51 the song has quietened down a little and I think your vocals already sit fine at this point.
I love the twin dry chugging guitars between 0:55 to 1:03, but I agree with the others that some added reverb would help in other places to enrich the mix.
Hope this helps - I'm looking forward to hearing the next mix tweaks! :thumbup:
Re: Hows my mix?
Postby Ractor » Sat Aug 24, 2019 7:21 pm
Thanks Martin. This helps greatly. ! And to everyone else also. This is priceless. I can hear everything you guys are saying now. So im basically remixing the whole thing. I found i had alot of stuff over processed. I also tried to add some semblance to the first and last megaphone parts. And i changed everything just alittle. So im cleaning it up. I should have a new version today. Hopefully im going in the right direction :)
Ractor
Re: Hows my mix?
Postby Ractor » Sun Aug 25, 2019 3:04 am
Here is the updated version. I still have to lower the hihat just alittle. https://youtu.be/PRGUM-LDeV8
Ractor
Re: Hows my mix?
Postby blinddrew » Sun Aug 25, 2019 8:35 am
Just had a quick listen on headphones and that's sounding more coherent to me.
Hi-hat level sounded fine.
Re: Hows my mix?
Postby tsongming » Sun Aug 25, 2019 9:31 am
Martin Walker wrote:Hi Ractor, and welcome to the SOS Forums! 8-)
Hey Martin ,
I just joined SOS simply to tell you that the song was amazing! As far as the mix is concerned, I listened to the song twice, and it reminds me a little of Tool, who I love.
No doubt, there are a couple of moments that need to be tweaked, but you have already increased the vocal volume, there is a copy of spots that sound a little flat but no big deal. I believe that if you add a couple of minor additions such automated panning, stronger compression on some of the vocal parts etc, that could still improve something that is great already into something that is just stellar. For example, at !:10, I feel that if you added a very subtle distant phrasing guitar riff or maybe very subtle strings, or maybe a cello, would be a nice addition. I will listen to it more because as I mentioned I really enjoyed it. Thanks for sharing.
tsongming
Re: Hows my mix?
Postby Martin Walker » Sun Aug 25, 2019 1:14 pm
Ractor wrote:Here is the updated version. I still have to lower the hihat just alittle. https://youtu.be/PRGUM-LDeV8
Wow - loving this mix Ractor. The vocal hang together so much better in the context of the track, and the the harmony vocals now ring through loud and clear.
I see you've added a little reverb to those chugging guitars and this does work well in making them sound even bigger.
Only two points occur in this latest listen.
1. The megaphone-style vocals sound great and are much better balanced, but I did feel the clean vocal sections (e.g. 1:09 onwards) might be more powerful if they were more 'up front' and intimate, and had a little less reverb.
2. The I found the ending a tiny bit disappointing - you have SO much power in the rest of the track, and then the end just seems to fade out (a little too quickly) leaving some hiss. Perhaps a single final guitar ending 'chug', a short squeal of feedback, a drum hit, but I do think it needs something with more punch.
Don't leave your listeners underwhelmed after such a wonderful track! ;)
Re: Hows my mix?
Postby Martin Walker » Sun Aug 25, 2019 1:16 pm
tsongming wrote:Hey Martin ,
Hi tsongming, and welcome to the SOS Forums! 8-)
Glad you like this track as much as I did, and thanks for your more detailed comments, but it's by Ractor, and not me ;)
Martn
