Improving wi-fI signal from router to my music computer.
Postby Arpangel » Sat Nov 16, 2019 11:08 am
I've finally got around to setting up a little studio in our tower, but the wi-fi reception is terrible. I need it to use Reason, it's authorised on my main studio computer, but on my PC in the little studio I have to be online to use it.
Obviously, the tower is at the top of the house, the router is on the middle floor, with two floors and walls in between the PC! We can't move the router, as it gives good reception in other parts of the house. It's going to be awkward to run a cable, and I'm wondering about those plug-in mains internet boosters, do they work?
Re: Improving wi-fI signal from router to my music computer.
Postby The Red Bladder » Sat Nov 16, 2019 11:39 am
Q: do they work?
A: Yes. They are a bit slower than a direct link, but they do work.
But before you do that, try using a dedicated wi-fi dongle, as the on-board wi-fi for most laptops is pretty crap. Look on eBay for a "600Mbps Dual Band 802.11ac 2.4GHz 5GHz PC WiFi USB Adapter" - they cost about £8 and are well worth it. I just use those and got one for M when her on-board thing was useless.
https://www.ebay.co.uk/itm/600Mbps-Dual ... Swv-ZaQYxS
They should not require any SW installation for W10 systems.
If that doesn't work, get a set of those BT mains adapters from Curry's-PC World for £30.
The Red Bladder
Postby shufflebeat » Sat Nov 16, 2019 12:15 pm
I use the mains extension adapters when the kids are having get togethers in the conservatory/garden where WiFi doesn't reach but they need something to maintain their life-support systems. I put a cheap WiFi doofer on the end and set up a separate network and password.
When the Good Lady Wife is doing her special thing (whatever that is) on SkypeTime I do a direct ethernet cable link via the extender to her laptop in the East Wing which works like lightning.
shufflebeat
"Dancing Queen - feel the heat from the tangerine, ooh yeah!"
Postby Agharta » Sat Nov 16, 2019 2:11 pm
The first thing to do is to check that the device and the router are both using the optimal protocols and channels etc.
Which for mainstream equipment might mean WiFi AC at 5GHz using a channel that isn’t conflicting with that of a neighbour.
Some equipment won’t default to using the best settings and the results can be dire.
I suggest installing a tool such as Wifi Analyser on a phone/tablet as that will show the strength of signal around the house on both the 2.4 and 5 GHz channels:
https://play.google.com/store/apps/deta ... yzer&gl=GB
Do post the make and model of your router as that can help.
If all the above is gobbledygook to you then look for a guide online about optimising WiFi as this is a basic and necessary skill nowadays.
Homeplugs and WiFi extenders both work and again I’d look for a guide that explains the basics so you can make an informed decision.
Agharta
Postby blinddrew » Sat Nov 16, 2019 6:47 pm
Do you actually need wifi or would a homeplug do? If so i'd recommend the latter.
Postby IAA » Sat Nov 16, 2019 6:57 pm
Q: do they work?
They are slower but some models have an Ethernet port which I find more reliable than their wifi.
IAA
Postby CS70 » Sat Nov 16, 2019 8:09 pm
First thing , which router do you have? There's unbelievable crap out there, and often simply a better radio and antennas in the router does the trick.
If your router is already a good spec, then it's worth exploring other solutions.
Running a cable is usually not so complicated. A possible trick I have sometimes employed when helping friends is to set up a second router in bridge mode, connected wirelessly to the main router in a place where the signal is strong, and run the physical cable from that.
Postby ef37a » Sun Nov 17, 2019 1:21 am
I had a very similar problem matey about a year ago.
I had a WI FI camera in the garden which needed better than an 80% signal. My TTlk router at the time gave good coverage around the house, even the kitchen, most remote point, but dropped off just 2mtrs beyond the kitchen window.
I used a run of CAT 5e cable some 10 mtrs as the crow flutters from router to kitchen door. That fed a TP-Link WA500G 54M 'wireless access point' and that gave the camera 100% signal. You don'r need you see to get the cable all the way, just close enough to another radiator. I guess you could use any gash router you have about? I have about 3.
The camera has gone back to Zon and I have my money back. I now have the latest TTlk router and that is very powerful.
I am not a fan of putting RF down the mains supply.
Postby Arpangel » Sun Nov 17, 2019 10:05 am
Thanks for all the replies folks, I'm using whatever is the latest Virgin wi-fi router.
Reception is fine in the rest of the house, im now expecting it to go through two Victorian ceilings and about four walls! We have to have the router in the middle of the house, to give even coverage, but the tower is two floors above that.
Yesterday we bought a TP Link AV600 power line. I'm going to try that today, I'll keep you posted.
Postby Arpangel » Sun Nov 17, 2019 11:13 am
Yeeeesssss! It works! It was a bit tricky setting up, as I had to run within 2mins to press the pairing button on the device in the tower, it's all Ethernet so the nieghbours wont be getting our signal....hopefully..... :o
Postby blinddrew » Sun Nov 17, 2019 11:28 am
Good news Arpangel. :)
I've been using homeplugs for a few years now with no issues and will be doing the same in the new shed.
ef37a wrote:I am not a fan of putting RF down the mains supply.
Out of curiosity, why not?
Postby Wonks » Sun Nov 17, 2019 11:41 am
The current Virgin hub doesn't have the greatest wi-fi strength in the world. I couldn't get a reliable signal in the bathroom maybe 25' away on the same floor, so now have a Netgear wi-fi router for that (though there are better/stronger wi-fi routers available).
Postby James Perrett » Sun Nov 17, 2019 12:34 pm
I'm not sure what Dave's issues with them are, but I've seen quite a few radio enthusiasts complain about them as the frequencies they use lie in the short wave bands which makes listening out for distant stations impossible if your neighbours are using these adaptors.
Postby ef37a » Sun Nov 17, 2019 12:35 pm
blinddrew wrote:Good news Arpangel. :)
Because I have bad memories of baby monitors and similar devices blarting out on peoples radigrams!
Ok, they were primitive analogue RF devices but the practice just still seems wrong to me, there is already a lot of telemetry going through the mains, those 'no-so-smart' meters for one thing.
Thank you James. Ihad not heard of any specific problem until now but there you go!
I am surprised it is allowed.
Postby blinddrew » Sun Nov 17, 2019 9:41 pm
Ah, thank you for the information.
