Overdrive unit/pedal for warming digital synths?
Postby Arpangel » Fri Dec 13, 2019 10:13 am
I've been using mainly analogue synths for awhile now, my Mini Moog, Eurorack, for a bit, and now my Buchla. All I can think of is that I've got used to a ceartin type of sound.
But now I'm revisiting my old digital stuff, my A--Station is fine, that has a sound that's unique, and I don't mind that, but I have an Alesis Micron and a Proteus 2000 that could benefit from a bit of a warm up.
I know there are various ways of doing this, more obvious chorusing or layering, but that's not what I'm after, all I need is a thickening, warming up of the sound, I'm after a stereotypical tube sound, not something subtle, a cliched valve sound, harmonic distortion.
Re: Overdrive unit/pedal for warming digital synths?
Postby The Elf » Fri Dec 13, 2019 10:39 am
Still can't say I interpret distortion as being 'warmth', but...
https://www.soundonsound.com/forum/viewtopic.php?f=23&t=47153
Postby Arpangel » Fri Dec 13, 2019 10:49 am
The Elf wrote:Still can't say I interpret distortion as being 'warmth', but...
That thread mentions the ART Tube preamp, I'm thinking along these lines, but I'm also thinking of maybe putting things through an amp, for a more dramatic effect.
Maybe distortion is the wrong word, I can hear in my head what I want, it's just bigger, warmer, I can cut the top,end and hoist the bass and lower mid, but that's not it, I think it may be the harmonic distortion of valves, they seem to do everything but don't rob the sound of clarity, it's like something nice has been added.
Postby The Elf » Fri Dec 13, 2019 10:50 am
dbx386? At some point you're likely to need stereo.
Postby Arpangel » Fri Dec 13, 2019 10:58 am
The Elf wrote:dbx386? At some point you're likely to need stereo.
Elf, I definitely need stereo, from the beginning.
This is a "saturated" market..... :blush: sorry!
The first thing that comes to my mind is the Culture Vulture, but that's stupid money, but this is like buying a suit, and just as personal, a fifty quid pedal might do it, ad we are talking about a little hundred quid synth, its not worth spending too much.
Postby The Elf » Fri Dec 13, 2019 11:42 am
Arpangel wrote:Elf, I definitely need stereo, from the beginning.
Then I'd definitely put the dbx386 on your check-list. I thought those ART Tube boxes were all mono?
I'd recommend my beloved VKP-1, but I have only seen one other in many years of searches.
Postby ef37a » Fri Dec 13, 2019 12:41 pm
They have been around for over ten years now and are seen as a bit 'Marmite', mainly because of size and power requirement but the Blackstar HT pedal range are noted for a good OD sounds and are very controllable. Might picjk one up cheaply second hand.
The 'warmf' is generated by a double triode and unlike most other 'toob' pre amps, these run at the right, ouchy, 300V HT.
Most versatile of the lot is the HT-Dual and that also has a speaker emulated second output ideal for recording or feeding a PA. Designed for guitar of course but the tone controls have vast range. TMB plus a sweep notch filter.
Got a good review in the mag.
Postby Dan LB » Fri Dec 13, 2019 1:10 pm
Elektron Analog Heat?
https://youtu.be/PQXPARuCXZg
There’s a MKii version now too.
Dan LB
Postby Arpangel » Fri Dec 13, 2019 2:05 pm
I'm not after a "hovering on the edge" type of sound, just a "nice" valve processor, it's getting that balance, or getting something with a fine degree of control, I just want my Micron to sound like an Oberhiem through a Fender Dual Showman, come on chaps, is that really too much to ask?
Postby The Elf » Fri Dec 13, 2019 2:12 pm
Arpangel wrote:I just want my Micron to sound like an Oberhiem through a Fender Dual Showman, come on chaps, is that really too much to ask?
Yeeeeeeeeeaaaaah...
Have you considered a new synth?! :wink: :lol:
Postby Arpangel » Fri Dec 13, 2019 2:20 pm
Yeeeeeeeeeaaaaah...
Yeeeeeaaahhhhh????? Oh, OK then!
:D :D
I loved my Micron, got loads of good sounds for it, but lately it sounds so damn thin, for some reason.
Postby blinddrew » Fri Dec 13, 2019 2:20 pm
And an amp perhaps? ;)
Postby Arpangel » Fri Dec 13, 2019 2:23 pm
blinddrew wrote:And an amp perhaps? ;)
I've got a Roland Guitar Cube, I'll put it through that with a bit of drive, it's got a recording output, I'll try that.
Postby The Elf » Fri Dec 13, 2019 2:26 pm
Whatever the question now is, the answer is "Novation Peak".
My work here is done! :D :beamup:
Postby Arpangel » Fri Dec 13, 2019 2:40 pm
The Elf wrote:Whatever the question now is, the answer is "Novation Peak".
I've just passed the Peak, I'm on my way to the Summit...
