best DAW
best DAW
Postby Omino » Wed May 20, 2020 5:05 pm
hi guys i need help to get more response for University/collage assignment can do me favour on filling the quick survey it will only take a minute to complete
thanks
https://forms.gle/RP4duTBwc1QvAQcu9
Omino
Re: best DAW
Postby Sam Spoons » Wed May 20, 2020 5:25 pm
Done, and yes it did only take a minute :thumbup:
You ask the question "which is the best DAW for beginners?" but don't give an opportunity to answer it.
Re: best DAW
Postby The Elf » Wed May 20, 2020 5:26 pm
Neither Pro Tools or Cubase (amongst others) in the first list...
i'm afraid I lost faith at that point!
Re: best DAW
Postby John Willett » Thu May 21, 2020 10:27 am
I started off with Fast Eddie in the 1990's.
There are lots of great DAWs missing from the list - Samplitude is excellent an d totally missing, for example.
If the questions is what did you use when you started, older DAW software options should have been included, some of which no longer exist.
John Willett
Re: best DAW
Postby Sam Spoons » Thu May 21, 2020 11:05 am
I actually started with a Yamaha Music Computer CX5M (it had a two operator DX synth engine IIRC) but as it's sequencer only did midi I wouldn't consider it a DAW as such.
Re: best DAW
Postby Eddy Deegan » Thu May 21, 2020 1:22 pm
My first 'proper' music software was Steinberg Pro 12 which I bought at one of the Computer shows at Alexandra Palace in the '80s.
(I couldn't afford Pro 24!)
No audio at that point, but you can't have everything :tongue:
Re: best DAW
Postby James Perrett » Thu May 21, 2020 1:54 pm
John Willett wrote:If the questions is what did you use when you started, older DAW software options should have been included, some of which no longer exist.
At least he included the option of Other and then a space for you to enter the name. There are probably quite a few of us who have never used anything in the list so it is a sign of a well designed survey that we are catered for.
Re: best DAW
Postby The Elf » Thu May 21, 2020 1:57 pm
I began on Commodore 64 (was that Pro-16?). Then it was a suped-up Atari ST.
I recall SOS loaning me an Atari Falcon that could record 8 stereo audio tracks alongside MIDI. It blew my mind! :o
Re: best DAW
Postby DC-Choppah » Thu May 21, 2020 4:53 pm
Voyetra Sequencer Plus was my first. I used it along with a TASCAM four track. Was that a DAW?
Does anyone still use Voyetra? That would be cool, to get that running inside ProTools!
DC-Choppah
Re: best DAW
Postby MOF » Thu May 21, 2020 5:10 pm
I started with Pro24, I didn’t know there was a Pro12. I quickly upgraded to Cubase when that came out for its logical, to me, arrange page. I struggled with the loop based approach of Pro24.
Strictly speaking I started out with something on the Sinclair Spectrum, so long ago I can’t remember what it was called, but I do recall it involved soldering up a kit for midi conversion that didn’t work.
MOF
Re: best DAW
Postby innerchord » Thu May 21, 2020 8:06 pm
Eddy Deegan wrote:My first 'proper' music software was Steinberg Pro 12 which I bought at one of the Computer shows at Alexandra Palace in the '80s.
I was probably there too! :wave:
I recall shady-looking guys trading cracked copies outside...
innerchord
Re: best DAW
Postby Dave B » Thu May 21, 2020 9:10 pm
Sam Spoons wrote:I actually started with a Yamaha Music Computer CX5M (it had a two operator DX synth engine IIRC) but as it's sequencer only did midi I wouldn't consider it a DAW as such.
It was full 4 operator FM on the CX5M - I used to use one at secondary school and learned FM programming on it. Then promptly forgot it when I got into analogue synths. Yes I know that's the wrong way round...
Dave B
Re: best DAW
Postby Sam Spoons » Thu May 21, 2020 9:23 pm
Thanks, it was a long time ago....... :blush:
Re: best DAW
Postby James Perrett » Thu May 21, 2020 10:08 pm
DC-Choppah wrote:Voyetra Sequencer Plus was my first. I used it along with a TASCAM four track. Was that a DAW?
Voyetra was my first computer sequencer too - and it spoilt me for just about every other piece of music software because it was so reliable. It never crashed - and it was in use in the studio nearly every day. There's another ex-Voyetra user around here too (hint - take a look at the editorial in some of the early SOS issues). I wouldn't consider a sequencer as a DAW though.
Voyetra's first DAW was Digital Orchestrator Plus which I also used for a while. The audio side was fairly primitive but it was easier than running SAW (my first DAW) alongside Sequencer Plus when I wanted MIDI and audio together.
At one point you could download Sequencer Plus for free from Voyetra but I can't see that download any more - although while searching I found that someone had got it running on a Raspberry Pi.
Re: best DAW
Postby Mike Stranks » Fri May 22, 2020 8:00 am
... and I'm still left wondering if the O/P is intending to print-off, cut-out, and stick the responses on a bigger piece of paper before submitting his thesis... ;)
