TRS to TDIF - No audio sending/receiving.. MOTU 2408MK3
Re: TRS to TDIF - No audio sending/receiving.. MOTU 2408MK3
Postby Hugh Robjohns » Sat May 23, 2020 12:00 am
I was trying to think how you could use those TDIF inputs... Apart from buying an old Tascam or Yamaha console fitted with TDIF option cards, there were a few multichannel digital preamps with TDIF outputs... And you might find some on fleabay or other outlets for ancient obsolete gear...
Tascam certainly made an 8-channel preamp/converter called the MA-AD8. And I think Apogee did an eight channel TDIF converter too (Rosetta 800 maybe).
But you'll be looking at gear that is around 15-20 years old...
Postby James Perrett » Sat May 23, 2020 12:11 am
The other suggestion would be to use a TDIF to ADAT convertor which would allow you to use a Behringer ADA8200 (or something better) for both inputs and outputs. Convertors like the Tascam IF-TAD seem to go for around £70 on Ebay.
Postby Ramirez » Sat May 23, 2020 7:28 am
Hugh Robjohns wrote:I was trying to think how you could use those TDIF inputs... Apart from buying an old Tascam or Yamaha console fitted with TDIF option cards, there were a few multichannel digital preamps with TDIF outputs... And you might find some on fleabay or other outlets for ancient obsolete gear...
There is the old RME ADI-8 Pro as well. We have a few of these still in use and working well with ADAT and TDIF.
Fair point that a huge ugly old mixer is not the most sensible way of getting 8 signals in!
Michael, I’ll PM you regarding rhat deleted message anyway.
Ramirez
www.stiwdiosain.cymru
Postby andy cross » Sat May 23, 2020 3:41 pm
Is there any reason why you can't use the 3x 8-channel ADAT i/o on the MOTU?
andy cross
