Yamaha MFC10 Foot Control Not Sending MIDI
Postby csarami@ncsu.edu » Wed Jan 13, 2021 5:34 pm
I have connected the MIDI out of MFC 10 to Yamaha to Yamaha workstation keyboard: PSR-A3000 (newer model) which is connected to iMac via USB. I have programmed MFC 10, foot control to send cc 11 ( expression).
However, When I move on the foot control it doesn't send any midi messages. I am monitoring it using a MIDI monitor app on iMac.
Since MFC is not USB, I have added it into Mac's MIDI studio as general midi but its Icon doesn't lid up when I press on MFC footswitches and control.
The MIDI Preset on PSR is All Parts. I have learned that Yamaha PSR by default have midi thru on. According to the manual of MFC 10:
Status Second Third
BnH 0BH vvH
I have set:
n = 0 ( channel 1)
vv = 127 on MFC10.
Am I doing anything wrong?
I noticed that one cannot send expression via joystick ( live control) and foot or Keyboard panel as there is no option in the function list ( Articulation 1, ... OST-).
My goal is to send cc 11 to Kontakt 5 from a controller.
So this is not possible and should I use another approach?
PS. I can do it with Touch OSC.
csarami@ncsu.edu
Re: Yamaha MFC10 Foot Control Not Sending MIDI
Postby The Elf » Wed Jan 13, 2021 6:29 pm
Simple things first. Try swapping out the MIDI cable.
Postby csarami@ncsu.edu » Mon Jan 18, 2021 12:59 am
It worked! The cable was supposed to brand new.
Thank you!
csarami@ncsu.edu
Postby The Elf » Mon Jan 18, 2021 1:19 am
