But to the OP: Elf's advice is invaluable. Keep it simple. Don't do stuff "just because" - every move you make in a mix should have a reason, and if you don't know what you're trying to achieve, don't do it.
Take an effect (say compression) learn its basics, and then try to achieve a certain goal (say you want to make sure there's no level lower than -20dB and higher than -10dB, stuff like that), and go back re-reading in case of trouble. It's gonna take some time but it's not rocket science, it just takes patience, method and practice.
