BobTheDog wrote:Can you init a patch on the hydrasynth, then go to voice and select mono.
Now with the roli in mpe mode slide two notes, on yours only the last played is effecting the pitchbend not both of them?
I play two notes (only one sounds, obviously). Whichever I bend, when I let go the pitch returns to the correct pitch of the still-held note. That seems as it should be to me.
If you mean that pitchbending both held notes starts a fight between them - yes, but it's in mono, so I would expect that too - you're sending two lots of bend data for a monosynth. Again, I'm fine with this.
I have the Hydrasynth keyboard.
