I will also add the frequency response of the room so that if anyone has advice in working on DIY panels to help with the other peaks and troughs of the graphs. I was also told I could fix this with EQ my speakers, how do I do this?
Thanks!
Sam Spoons wrote:How big is your room?
DelOro wrote:Also, and sorry for the multiple post still new to this, regarding richard's statement its not bass absorbers but panel absorbers? these would need to be at the reflection points and not the corners. How thick would the frames have to be? and for the vocal placement I was thinking of making the position in the middle with a mic shield as well as removing panels to create a roomier sound. If that makes sense.
For the bass absorbers they would be too big for the room? I'm guessing at least 5 feet deep right?
Sam Spoons wrote:A better (probably) plan is to include some 'limp mass' panels in front of or internal to your bass traps. Hugh did as 'proper job' in his studio recently, detailed in this article https://www.soundonsound.com/techniques/studio-sos-making-small-room-sound-good
Martin Walker wrote:Sam Spoons wrote:A better (probably) plan is to include some 'limp mass' panels in front of or internal to your bass traps. Hugh did as 'proper job' in his studio recently, detailed in this article https://www.soundonsound.com/techniques/studio-sos-making-small-room-sound-good
+1 for this advice from Sam, and also a +1 for broadband absorbers first of all. to help flatten out all the other room modes.
However, even 100mm thick absorbers placeed across the corners won't really affect much below 100Hz, so if you really expect a big problem at 55Hz you'll require seriously big treatment, placed carefully for maximum effect.
Oh, and welcome to the SOS Forums DelOro!![]()
DelOro wrote:I have done a bit of research and realize that, yes, filling the corners it would require a lot of space which I unfortunately don't have. One idea I have found was adjusting my monitors closer to the walls. This has to do with the Speaker-Boundary Interference. Right now I have it like a foot and a half off the wall. What if I put the speakers closer to walls with absorption panels right behind it. I am just trying to figure out how thick the panels should be.
Please let me know if this is a possibility
Martin Walker wrote:It's impossible to say with certainty, as each room tends to be at least slightly different. However, I've certainly done this in my tiny studio, because you do largely avoid the SBIR problems if your loudspeakers are very close to the wall.
It works particularly well for me because my loudspeaker cabinets are sealed rather than ported, so their bass end naturally falls off smoothly from a slightly higher frequency, and by placing them with their backs a couple of inches from the wall the reflection from this wall simply boosts their low end response to provide an overall smooth bass extension.
If on the other hand your loudspeakers are already voiced with a more reinforced bass end, they could end up sounding bottom-heavy and boomy when placed against the wall.
