Dumping sounds from the Roland SH01a to computer
• Page 1 of 2 • 1, 2
Do I need to download a special program from Rolands website?
- Stickman0_3
- Regular
Re: Dumping sounds from the Roland SH01a to computer
Nothing about this in the manual?
desmond - Jedi Poster
OK, I have it now, I must have read it wrong.
- Stickman0_3
- Regular
Hi, sorry to bring this up again.
After much head-scratching, I think I have this now. Is this the process?
1. Copy backup files from SH01a drive that shows up in “Documents” + “USB Drive” on my PC..
2. Place them on the desktop
3. Rename the folder to what I choose
4. Then, perform a Factory Restore on the SH01a - (I’m not interested in storing patterns)
- Stickman0_3
- Regular
Still not getting this guys, sorry.
- Stickman0_3
- Regular
OK, I think I’ve got this, but can someone clarify this for me please: -
1.Anything I program into the SH01a will appear in the SH01’s usb drive?
2.I then copy the sounds from the drive into a folder on my desktop, name the file (ie - file 1)?
3.Lastly, if I want to load “file 1” again, I copy those sounds from “file 1” into the Restore file?
- Stickman0_3
- Regular
Now, my SH01a's drive has disappeared, how can that be?
- Stickman0_3
- Regular
Because you either:Stickman0_3 wrote:Now, my SH01a's drive has disappeared, how can that be?
(a) skipped step 1
(b) Ejected it
(c) Need a driver update (not likely if it worked the first time)
Tomás Mulcahy - Frequent Poster
How do I get it back?
- Stickman0_3
- Regular
OK, I've got it back now. And I shall start again tomorrow.
- Stickman0_3
- Regular
Please excuse my ignorance, I may be a little bit slow off the mark in understanding.
On the Roland SH01a, when I get into the menu and scroll through the parameters, there is a parameter in the menu called “CCnd”. Does this need to be on in order for the SH to send and receive data through the midi/usb connections?
Can someone explain CC messages to me?
Once again, please excuse my ignorance.
- Stickman0_3
- Regular
MIDI controller messages are simply messages that contain a controller value, maybe derived from a slider, or knob. They consist of a byte denoting the type of controller (often short-named 'CC') and a byte containing the controller value in the range 0-127. CC11, for example would imply an expression message.
To complete this example, a MIDI Expression message might look like '0B 0A' in hexadecimal. This translates as 'MIDI Expression = 10'.
But without the context of what you're reading it's hard to know whether the above is relevant.
The Elf - Jedi Poster
I simply want to dump my sounds out via USB or Midi. I've switched CCnd to On. My SH01a is version 1.02, do I need to update to 1.07 in order to dump out?
- Stickman0_3
- Regular
Looking at the manual that parameter tells the synth whether to transmit all its patch data as CC values on patch selection. If you recorded that in a DAW it should be able to recreate the patch when re-transmitted back to the synth.
I think I may have backed up my sounds at last. BUT...I did it a totally different way to what it says in the manual.
Only time will tell whether I have or not, fingers crossed!
- Stickman0_3
- Regular
