Hello, this might get really technical and geeky. I don't know anything about cables and what makes a good cable or a bad cable.
I need a 15 ft USB C to USB A cable to go from my Steinberg UR22 to my mac.
Is there a superior cable brand? Is it possible for a bad cable to add noise to my signal?
What data transfer rate should I ensure the cable has?
Just want to make sure I do my research before buying a cable. Anything on Amazon you can recommend also?
Thanks in advance. Sorry if this is a stupid question.
Cable recommendations for audio interface connections
• Page 1 of 1
- timetorecordstuff
- Poster
Re: Cable recommendations for audio interface connections
Assuming you're talking a USB cable, the Lindy ones get a good nod round here, and a 15ft you'll be wanting a decent one.
blinddrew - Jedi Poster
blinddrew wrote:Assuming you're talking a USB cable, the Lindy ones get a good nod round here, and a 15ft you'll be wanting a decent one.
Yes a USB A to USB C. Thank you!
- timetorecordstuff
- Poster
+1 for Lindy - their name almost inevitably pops up when people here recommend long digital cables.
Martin Walker - Moderator
So I'm in Canada and having a really hard time finding a way to purchase a Lindy cable. Anyone have any luck finding one in Canada?
- timetorecordstuff
- Poster
timetorecordstuff wrote:So I'm in Canada and having a really hard time finding a way to purchase a Lindy cable. Anyone have any luck finding one in Canada?
Interestingly enough you can buy some of their cables from Walmart but not the long USB cables.
Amazon.ca also seem to sell their cables.
James Perrett - Moderator
Before you spend out do check the Steinberg manual to see if they suggest a maximum length of USB cable.
The common standard is 5mtrs I understand but some interface makers consider 3mtrs to be a safe maximum. I found this to be the case with my Naive Instruments KA6. Would not 'lock' on some 5mtr cables and one computer, would on another. The 'good' cable was indeed a Lindy.
You can get 'active' USB cables that extend well past 5mtrs but AIs can be fussy sod's and I have never tried one. Maybe a re-think of the layout? Have a 3mtr USB link because you can extend mic and balanced output cables almost ad.inf?
Err? My picture of a UR22 shows a USB "B" port. I assume the mac only has C ports so you want a 5mtr "C to B" USB cable. Probably only found under rocking horses. I am sure you can get adaptors.
- ef37a
- Jedi Poster
AFAICT a USB C to B adapter does not exist but you can get C to B cables although 5mtrs might be a bit of a stretch.
- ef37a
- Jedi Poster
I guess the adapter you are thinking of (and doesn't exist)* would be a USB C female to USB B male? A USB C - USB A female adapter would get you there at the computer end of the cable but yes a USB C (host) to USB B cable would be a neater solution.
* Adapters are rarely made to fit at the slave end of the cable IME.
Sam Spoons - Jedi Poster
According to the Steinberg website, the UR22 has a USB2 Type B socket.
So you need a USB2 type B plug to USB3 type C plug. Nt sure if they are available in the lengths you need.
So I would suggest you source a good quality USB2 type B plug to USB2 type A plug cable of the length you require (this will probably be the easiest type to find for longer lengths) and then use a USB2 type A socket to USB3 type C plug adaptor. Apple make a suitable adaptor, at typical Apple prices, and I have a couple of them. One is being used for my Arturia Keylab 49 which is supplied with a short USB-B to USB-A cable.
I presume other similar adaptors are available.
Andy
Andy
zenguitar - Moderator
liberté, frivolité et vanité
Hmm? I 'quite' like the USB C connector. The plug seems pretty robust and the 'any way round' is a great idea, especially for those of us with less than 20-20 minces!
But, did it HAVE to be SO dinky? Why could the standard plug not be about the same size as a USB A jobby but keeping the solid construction and round edges? I also think the current connector will be prey to dirt and damage? Especially for 'pro/road' use?
The present one could have been reserved for phones and other small format devices. There is already a huge USB 'zoo' so one more adator lead would have made little difference and most of the others will die out eventually anyway.
- ef37a
- Jedi Poster
